Author Topic: accelaration problem  (Read 3678 times)
March 09, 2009, 02:13:34 pm
brfvan
  • 1
« on: March 09, 2009, 02:13:34 pm »
Hi volks idi newby here, I just installed 1.6td jx code (imported from Germany it is a factory vanagon TD engine) in my vanagon. After lots of fun I was able to get the engine started but it will only idle, it idles smoothe but when I try to rev it from the IP nothing happens it still just only idles. Any suggestions?
Cheers,
B
Reply #1April 01, 2009, 08:12:13 am
74superman
« Reply #1 on: April 01, 2009, 08:12:13 am »
Were you able to get this straightened out?  I'm having the same problem with my 1.5 na.  Let me know.  Thanks.
Reply #2April 01, 2009, 05:07:10 pm
Re: accelaration problem
« Reply #2 on: April 01, 2009, 05:07:10 pm »
Quote from: "brfvan"
Cheers,
B
did you modify the pump in any way? did you need to time it, or did you just install the engine as is and get it to run?
