Author Topic: 1.6 td from poland... how to make my td more strong:s  (Read 5407 times)
March 09, 2009, 01:47:54 pm
jabcok20
  • 15
    1.7 m-tdi vnt20 electronic map sensor
« on: March 09, 2009, 01:47:54 pm »
helo. at start sorry for my english...
i have 1.6td engine in my golf mk1. i have done timing advance mode and gov mode.
i have installed turbo vnt20 with N70 and electriccontrol used mpx.
 i have exhaust from 1.5 diesel original from my auto but i want to change it...
intercooler i have from bmw 2.5tds.
what can i do to make my  1.6td 1V faster?
 i change rings on pistons and I can do something else with my engine before i put it in car.
how to make down side of engine more powerfull. you know crankshaft?
Can i put more powerfull injectors ? From what car ( my have 155bar)
SB have 160...
Reply #1March 09, 2009, 02:31:57 pm
  • 3255
    • My collection of HOWTOs
« Reply #1 on: March 09, 2009, 02:31:57 pm »
Hi and welcome to the board.
Don't worry about your English... already I can tell you speak it better than most of us!  ;-)
I'd recommend you start by reading thru the FAQ ... it's got tons of good information and will answer at least some of your initial questions.  In particular look for a section called "Make your car faster" down a ways.
Once you're up to speed on the basics you're in a good spot to ask questions about the details.
Again, welcome aboard !!
Reply #2March 09, 2009, 02:47:11 pm
subsonic
  • 1836
« Reply #2 on: March 09, 2009, 02:47:11 pm »
I would suggest you add your location in Poland and then do a search for a member named:
zaprzal
He is also from Poland and should be able to help you out.
Good luck,
Reply #3March 09, 2009, 03:30:05 pm
79rabbit4dr
« Reply #3 on: March 09, 2009, 03:30:05 pm »
zaprzal's profile page, hope that helps!
« Last Edit: May 28, 2009, 08:46:18 am by 79rabbit4dr »
