Author Topic: Glow plug issues.  (Read 6765 times)
August 18, 2005, 08:55:03 am
addautomotive
Glow plug issues.
« on: August 18, 2005, 08:55:03 am »
I was away on a sailing trip a few weeks ago, and my wife had trouble starting the for a couple days, then one cool moring it wouldn't start at all. Took it to the garage and they replaced all 4 glow plugs, which were burnt down to the "nub" (my word). Unbeknownst to them, I had replaced all 4 glow plugs in the fall!
Now, only a month or so later, the car is smoky and rough on startup... I suspect the damn glow plugs are burnt again. What could cause this?
I've hooked up a test light to the GP buss bar, and the light goes out after 10-15 seconds or so. I've also tested it when hot to see if teh glow plugs are coming on when I hot-strat the car... they aren't.
Any ideas?
Reply #1August 18, 2005, 10:12:26 pm
  • 2932
burnt glow plugs
« Reply #1 on: August 18, 2005, 10:12:26 pm »
Could be an intermitant problem. They could be sticking some times but not all.
 I put a light in one of my cars that would shine in my face whenever the glow plugs had power. Knowing when the glowplugs were actually on was comforting ... sold that car but intend to upgrade other cars with this extra indicator.
 You might want to try that.
 I've also heard dripping injectors can cause the glow plug tips to burn away.
Reply #2August 19, 2005, 06:42:30 am
addautomotive
Glow plug issues.
« Reply #2 on: August 19, 2005, 06:42:30 am »
interseting... I'm going to hook one of those lights up.
Leaky injectors, eh? Maybe I'll run a dose of Diesel Purge.
Reply #3August 20, 2005, 12:02:03 am
  • 2932
car in your sig
« Reply #3 on: August 20, 2005, 12:02:03 am »
I forgot what kind of diesel you are driving.
 Put it in your signature.
 Not sure how much weight I put in the dripping injectors theory but I have heard of it happening before.
Reply #4August 20, 2005, 10:28:01 am
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
Re: Glow plug issues.
« Reply #4 on: August 20, 2005, 10:28:01 am »
Quote from: "addautomotive"
I agree that this problem points to injector problems.  I'll bet if you have your injectors tested, they will show problems either with bad spray pattern or leakage, like fatmobile suggests.  Having new nozzles installed in them (getting them rebuilt) should restore them to new condition and stop your glow plug erosion problem.
Jake Russell
Dieselicious Turbocharger Upgrade/Rebuild Kits
Reply #5August 20, 2005, 06:44:25 pm
addautomotive
Glow plug issues.
« Reply #5 on: August 20, 2005, 06:44:25 pm »
Thanks folks... it's a 96 1.9l TD. I've noticed that my mileage has been suffering, so injectors seem like a likely cause then.
I have a spare set of injectors off a used engine I just bought. What's the best DIY way to assess their condition? Will a visual inspection suffice?
Reply #6August 20, 2005, 09:46:47 pm
  • 2932
checking injectors
« Reply #6 on: August 20, 2005, 09:46:47 pm »
Take it to a diesel shop and have them tested for spray pattern, drip and breaking pressure.
Reply #7August 23, 2005, 12:51:01 pm
watsongs
  • 135
Glow plug issues.
« Reply #7 on: August 23, 2005, 12:51:01 pm »
Jake, where do you get your injectors tested/serviced?
Greg
Greg Watson
'79 Rabbit, 1.5 liters of fun...
If they can get you to ask the wrong questions, they don't have to worry about the answers...
Reply #8August 23, 2005, 10:28:56 pm
fspGTD
  • 1529
Glow plug issues.
« Reply #8 on: August 23, 2005, 10:28:56 pm »
Precision pump and injector service corp in Bellevue.  Jay and Bill are the father/son owners and are both great guys and they do outstanding work and are very patient, helpful and friendly too.  Tell 'em I sent ya.
Jake Russell
