Author Topic: How to measure head bolt size?  (Read 2357 times)
March 03, 2009, 09:17:33 pm
turbosyncrobus
  • 25
« on: March 03, 2009, 09:17:33 pm »
Here's a dumb question, where on the bolt is the measurement for the size of the head bolt taken? From a JX turbo block/mech. head I have 11.75mm across the threads, and 10.75 on the shank...Help.
Reply #1March 04, 2009, 05:00:01 am
turbosyncrobus
  • 25
« Reply #1 on: March 04, 2009, 05:00:01 am »
Thank You very much.
Reply #2March 04, 2009, 09:22:35 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #2 on: March 04, 2009, 09:22:35 am »
For measurement purposes, the threads would be measured across pins on the pitch diameter.  For practical purposes measure across the maximum diameter on the threads and round up as they will virtually always be under the nominal.   The measurement across the unthreaded portion may be the same or less depending on the design.  On stretch bolts it will almost always be less here to control the stretch.
Calvin
91 VW Golf 1.6NA 5spd
