Author Topic: WTS: Rebuilt Engines  (Read 3840 times)
March 02, 2009, 11:55:45 am
myke_w
  • 1099
« on: March 02, 2009, 11:55:45 am »
Hey guys, I've recently come across several AAZ and 1.6 TD motors that
I am planning on rebuilding and selling. In general I'm doing
longblocks but I have other parts too if needed.
I figured I'd mention this
here given all the people I know who have gotten burned buying a $2500
mystery motor and then regretting it.
About my process -
I strip & clean, magnaflux & check block, bore and install new
pistons, pins, bushings, rings and clips. I clean, check & polish
crank. I pressure check, clean and inspect head and do complete valve
job with seals and with valves and guides as needed, install all new
bearings, rod bolts, head bolds, headgasket, cam, crank and int seals,
freeze plugs, and can generally offer any other ancillary part you may
need to complete your rebuild or conversion.
All parts are of European origin unless unavailable (no garbage here)
If anybody has any interest, take a look at some of my work here.
http://www.thedubdoctor.com/parts_site/engines.html
Thanks all!
