Author Topic: Uh, oh...... oil in coolant.  (Read 4511 times)
March 01, 2009, 11:16:12 pm
westcoaster
« on: March 01, 2009, 11:16:12 pm »
Would I be a little too optimistic to think my problem exists in the oil/water cooler?
Head gasket? or could I be dealing with something far worse?
Aside from gooping up my rad and heater core what could happen from running it as is?
I bought an '87 jetta as an engine donor for my suzuki samurai.
Judging by the number of empty antifreeze bottles rattling around in the trunk (two) and the fact that it was low on coolant when I bought it the coolant is disappearing somewhere. Add the oil in the coolant and I think may have a problem.
There were quite a number of bolts missing between the tranny and the engine. Either one or the other or both have been swapped out in it's past. Not that big a deal now, but for 383,000 km the engine appears to run pretty strong.
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #1March 02, 2009, 08:25:44 am
arb
« Reply #1 on: March 02, 2009, 08:25:44 am »
I'd pull the head and check it for cracks / flattness. The gastket and studs will not set you back a ton, but will show you where you stand. You really don't want oil in the coolant as the hoses will fail sooner.
Reply #2March 02, 2009, 09:05:23 am
Golf/Jetta
  • 102
« Reply #2 on: March 02, 2009, 09:05:23 am »
i wouldn't use a FRAM oil filter.. buy oem or expensive
the filter is like a roll of towelette paper bent up
Fram ||||||||||
OEM ||||||||||||||||||||||||||
something like that
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #3March 02, 2009, 11:44:57 am
« Reply #3 on: March 02, 2009, 11:44:57 am »
hey, i had the same problem happen.. its just oil in the coolant. no coolant in the oil tho right? if thats the case.. its your oil cooler. just try plugging the connestions and taking the cooler off and putting your oil filter right on the filter housing where the cooler used to be, then clean out your cooling system with lots of dawn soap in the water. i wouldnt run anti freeze again till i know it was fairly clean. ill tell you what.. it was some messy S*it. but its possible that its a HG if the coolant is going somewhere. did it over pressurize the cooling system at all?
Reply #4March 02, 2009, 01:03:59 pm
kaneb
  • 164
    • www.dasdubbers.org
« Reply #4 on: March 02, 2009, 01:03:59 pm »
Its most likley your oil cooler. If it was the other way around coolant in your oil then i would be observing your head gasket and pulling the head.  I would first check out your oil cooler before pulling your head.
Make sure once it is fixed you flush the entire coolant system a couple times to get all the oil out.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #5March 02, 2009, 01:19:26 pm
« Reply #5 on: March 02, 2009, 01:19:26 pm »
Here's another way to look at it:  a breach between the oiling system and the cooling system is a breach.... be it oil cooler, headgasket, or cracked block.
The cooling system operates at 15psi, max.  The oiling system operates at 80+ psi.  So, the physics of the situation dictate that oil is almost always gonna be forced into the cooling system, regardless of where the breach is.
It can reverse, of course, if the cooling system is totally up to pressure and the engine is idling with thin hot oil in a worn engine (ie oil pressure less than 15 psi) or for a few minutes following engine shutoff (oil pressure 0, coolant still pressurized).... but in general it's gonna be oil -> coolant... pretty much regardless of where the breach is.  Other clues like the coolant system getting pressurized too early add to the story and help distinguish the suspect.
Obviously there are exceptions: weird forces come into play as soon as compression starts to leak in as well... and gravity might play a role in specific cases, but for your standard breach the system with the bigger pressure usually wins.  Or so Dr. Stephen Hawking assures me.:wink:
Reply #6March 02, 2009, 05:14:08 pm
westcoaster
« Reply #6 on: March 02, 2009, 05:14:08 pm »
Quote from: "Rabbit on Roids"
Right, oil in the coolant but no coolant in the oil. but then again, I don't know when the oil was changed last either....
I don't have any history on this motor. I only ran it 60Km from Richmond to Maple Ridge. Coolant not showing in overflow tank when I bought it plus two empty bottles of antifreeze in the trunk leads me to believe it is going somewhere.
I know about the fram filter "problem" My truck has a cummins diesel and that is the one thing they hammer at on filters for those motors as well. Something about the fram coming apart and forcing filter bits through the lube system....
I need to change the filter housing to an angled housing for the swap (I happen to have a different oil cooler for that as well) I may as well start with that and see if I continue to have a problem.
Dawn dish soap in the rad....
Well I suppose, can't really hurt anything.
Reply #7March 03, 2009, 09:51:59 am
« Reply #7 on: March 03, 2009, 09:51:59 am »
i swear to god.. dawn dish soap is the only cheap thing i could get that would cut all the greace. i mean c'mon.. if its safe to use on things we eat off of, then why wouldnt it be safe to put in your cooling system? i mean, its not corrosive or caustic. so its not gonna rust your block, eat your gaskets or seals, or make the head corrode. i just wouldnt run it in there very long. i ran mine with soapy coolant for about 3 days then drained it and filled it up with 'freeze.
Reply #8March 03, 2009, 03:31:55 pm
kaneb
  • 164
« Reply #8 on: March 03, 2009, 03:31:55 pm »
When we do in-frames at work on cat's and cummins when we put new liner's in we put a bit of dish soap on the orings to gently lubricate them.  Never used it for rad flush before though.  But if it works it works.
www.dasdubbers.org
Reply #9March 03, 2009, 04:37:53 pm
« Reply #9 on: March 03, 2009, 04:37:53 pm »
powdered dish soap works well too
Reply #10March 03, 2009, 05:38:41 pm
westcoaster
« Reply #10 on: March 03, 2009, 05:38:41 pm »
Ok, since we are talking about house hold products that cut grease, Laundry soap seems to do pretty well. I have used that to clean the floor after a a bunch of oil had spilled on it.
Laundry soap also won't foam up as much as dish soap.
Hmmmmm.......
Hijacking my own thread. :roll:
Reply #11March 04, 2009, 03:35:33 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #11 on: March 04, 2009, 03:35:33 am »
Cummins has told us to use washing soda for similar cases. (Fun cleaning out the coolant passages in an engine and the rad on a truck that someone filled the coolant system with hydraulic oil.) Drain as much coolant as you can, fill with water and add washing soda. Run up to operating temp (to allow thermostat to open). Drain, repeat until no sign of oil in coolant. Needless to say, this works best if you have the leak fixed first.
Calvin
91 VW Golf 1.6NA 5spd
Reply #12March 04, 2009, 07:13:27 am
westcoaster
« Reply #12 on: March 04, 2009, 07:13:27 am »
Quote from: "clbanman"
could you give an example of "washing soda"? brand name or similar?
Can't say I am familiar with that....
Reply #13March 04, 2009, 07:54:00 am
starrd
  • 128
« Reply #13 on: March 04, 2009, 07:54:00 am »
Quote from: "westcoaster"
Look in your super market, Arm and Hammer makes it
 - see link below - super washing soda
http://www.thelaundrybasket.com/Our_Products/our_products.html
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #14March 04, 2009, 09:17:43 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #14 on: March 04, 2009, 09:17:43 am »
Arm & Hammer is the brand we used but there are many available.
http://en.wikipedia.org/wiki/Washing_soda
Calvin
