Author Topic: Bought an '80 Caddy, WTB a few parts:  (Read 4784 times)
February 28, 2009, 06:05:25 pm
stabmaster
  • 14
« on: February 28, 2009, 06:05:25 pm »
I need the following, amongst other items:
e-brake cables and the solid ebrake tube that is welded onto the underside of the chassis (not sure if there's a better fix but it's broken)
vaccum pump (preferably #068 145 207 '84-98 rotary style)
front driver's axle
struts or strut cartridges
breather hose on top of engine (partially chewed up by rat)
fuel lines in rear- the rubber is sucking in air
Reply #1February 28, 2009, 08:42:07 pm
blkboostedtruck
  • 1535
« Reply #1 on: February 28, 2009, 08:42:07 pm »
whats your location? you should add that in your profile!
helps find you parts near you or so!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2March 01, 2009, 10:35:15 am
stabmaster
  • 14
« Reply #2 on: March 01, 2009, 10:35:15 am »
sorry i'll fix that. im in eureka, ca
there's like nobody within hundreds of miles of here - kindof out here in the woods
Reply #3March 01, 2009, 12:10:45 pm
blkboostedtruck
  • 1535
« Reply #3 on: March 01, 2009, 12:10:45 pm »
Quote from: "stabmaster"
wow thats wild i used to work for eureke mayflower movers back in the 80's
yes your right there's nothing but big trees and red wood trees i remember the most!
Duane
'66 variant 1500S
Reply #4March 02, 2009, 08:15:38 am
GEE-BEE
  • 1604
« Reply #4 on: March 02, 2009, 08:15:38 am »
EBRAKE CABLES
EBAY AT MK1AUTOHAUS / MOOGIE
[email protected] MAKES THEM FOR LONGER FOR DISC CONVERSION
FUEL HOSE , TAPERED TYPE , DEALER ITEM
GEE-BEE
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5May 01, 2009, 10:28:02 am
stabmaster
  • 14
« Reply #5 on: May 01, 2009, 10:28:02 am »
Thanks guys! I've since gotten ahold of all of the aformeentioned parts. It looks as though I'm in need of a vacuum booster/servo (e.g. brake booster/servo)
Can't seem to find anything. Any help is greatly appreciated.
Reply #6May 01, 2009, 12:34:35 pm
GEE-BEE
  • 1604
? BOOSTER
« Reply #6 on: May 01, 2009, 12:34:35 pm »
I found a new one on ebay for 150.00
There is another soUrce if you cant find it
EMAIL AT [email protected]
Giles Pump OHC
MK1 JETTA DASH
Reply #7May 01, 2009, 01:27:58 pm
stabmaster
  • 14
Re: ? BOOSTER
« Reply #7 on: May 01, 2009, 01:27:58 pm »
Quote from: "GEE-BEE"
best price i've found is remanufacturerd at partsplaceinc.
Reply #8May 01, 2009, 01:47:30 pm
ilikevwdiesel
  • 1202
« Reply #8 on: May 01, 2009, 01:47:30 pm »
I've got a vac pump for you I can throw in a USPS flat rate box what's it worth to you?
My Bio
Reply #9May 01, 2009, 04:38:05 pm
stabmaster
  • 14
« Reply #9 on: May 01, 2009, 04:38:05 pm »
Quote from: "ilikevwdiesel"
bahh i have 2 working vac pumps since i thought it was the vac pump. I need the servo ;) thanks though
Reply #10May 01, 2009, 08:13:24 pm
ilikevwdiesel
  • 1202
« Reply #10 on: May 01, 2009, 08:13:24 pm »
oops sorry misread that
My Bio
