Author Topic: Gattett T2 pics got any?  (Read 2651 times)
February 24, 2009, 10:02:59 pm
foxracer1
  • 991
« on: February 24, 2009, 10:02:59 pm »
I'm looking for pics of the Garrett T2s if you've got some could i see them? Thanks Ones from the VW diesels.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #1February 26, 2009, 01:35:12 am
TurboJ
  • 661
« Reply #1 on: February 26, 2009, 01:35:12 am »
Sorry, not got a better one right now...
Jetta II 1.6 TD 'Project 200'
Reply #2February 26, 2009, 04:48:39 am
« Reply #2 on: February 26, 2009, 04:48:39 am »
TurboJ, what's that sensor on what looks like the oil feedline?
Reply #3February 26, 2009, 01:30:25 pm
TurboJ
  • 661
« Reply #3 on: February 26, 2009, 01:30:25 pm »
It's actually the water line for the cooling of the bearing housing.
The sensor is the heat sensor that controls a separate turbo coolant pump.
When the turbo cooling water temperature reaches a set level,
the coolant pump is turned on and the coolant will flow until the liquid is cooled below the set level again.
And yes, that is a factory VW system!
I believe only the T2 had factory water cooling?
Reply #4February 26, 2009, 09:58:27 pm
foxracer1
  • 991
« Reply #4 on: February 26, 2009, 09:58:27 pm »
Quote from: "TurboJ"
Interesting. And thanks for the pic. I haven't seen to many T2s and am pondering some compound/twin thoughts.
91 S10 305 TPI T56
Reply #5February 27, 2009, 12:35:58 am
zagarus
  • 619
« Reply #5 on: February 27, 2009, 12:35:58 am »
if you still needed more pics :P
Reply #6February 27, 2009, 07:37:53 am
foxracer1
  • 991
« Reply #6 on: February 27, 2009, 07:37:53 am »
Those are cute little guys aren't they. Yeah more pics are fine i'm just brainstorming.
91 S10 305 TPI T56
Reply #7February 27, 2009, 11:11:24 am
TurboJ
  • 661
« Reply #7 on: February 27, 2009, 11:11:24 am »
Zagarus,
I don't see the coolant connectors on your T2...?
Does that mean only some T2s had water cooling?
Reply #8February 27, 2009, 05:24:46 pm
zagarus
  • 619
« Reply #8 on: February 27, 2009, 05:24:46 pm »
that is correct, mine did not have water cooling.  Turbo came out of a 1993 passat.
