is it predictable what temperature that steel can handle?
This will raise boost by simply not allowing the wastegate to open all the way and will send EGT's way up.I would leave that ajustment alone Or put a bigger spring in the wastegate.So for anyone else looking to raise boost on the k14,k24 the best way is to just put a bleed in the line or use a boost controller, just leave the screw alone!
And finally, a question. Is that just carbon in the groove? (red arrow) Is there supposed to be something in there?.
