General Information
Upgrades (non engine related )
lowest cruise speed setting
Topic: lowest cruise speed setting (Read 6016 times)
February 09, 2009, 07:26:26 pm
madrogers
February 09, 2009, 07:26:26 pm »
looking to find out what the lowest speed the factory cruise will start at.
in the early 90,s cars.
Thanks Mark.
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
February 09, 2009, 07:38:59 pm
February 09, 2009, 07:38:59 pm »
I believe the test said 60 kph but i have had them come on as low as 40. maybe even lower. If you want to test the system it has to be driven, not on jack stands.
February 09, 2009, 09:29:12 pm
madrogers
February 09, 2009, 09:29:12 pm »
why does it have to be driven?? it should kickin monentaraly at least I would think, I have wired the system up into my caddy and did the tests from info i found on the web ( no Bentely yet) and all inditcates it should work , but does not, I have tryed a second controller but it may be bad, I do not know , all looks good inside of it . not much info on the subject that i could find anywhere.
February 10, 2009, 05:59:14 am
February 10, 2009, 05:59:14 am »
It's a very good question which nobody at VW could answer for me either. But i have never been able to test on a lift or with the wheels up. Always had to be road tested to check functions. The only thing you can do with the wheels up is check the voltage values from the speed sensor.
February 10, 2009, 06:00:53 am
February 10, 2009, 06:00:53 am »
I have done lots and have my own trouble shooting guides so let me know if i can help.
February 10, 2009, 09:07:46 pm
madrogers
February 10, 2009, 09:07:46 pm »
thanks for the offer , if you have the voltage values that would help me , that could be my problem , i have no known good unit to go by . I have 1.2 volts at 65 kph, seems like it is good but I do not know for sure.
Thanks Mark.
February 11, 2009, 05:59:51 am
February 11, 2009, 05:59:51 am »
The voltage must change as the wheel is turned, i believe from almost 0 to 12v. I will double check in the next hour when i go into my garage.
February 11, 2009, 07:17:13 am
February 11, 2009, 07:17:13 am »
Okay big correction: 0-11.5 V . I found my guide which tests everything without the processor, so 99% of the time the test works. Let me know i can give you the steps. I just need to know if it's a 10+2 pin or 12 pin processor.
February 11, 2009, 12:51:56 pm
madrogers
February 11, 2009, 12:51:56 pm »
I have two controllers that i am trying out, the org one from the complet set up is a 1991 8 pin plus one ext ground pin all electronic and the second one is a 8 pin with 2 ext. pins it has the manual relay inside the box. the speedo is the 1991 with the plus genreator in it. like i said i can 1.2 volt a/c at 65 kph, your 0-11.5 volts seems high for small generater.
Mark.
February 11, 2009, 01:03:05 pm
February 11, 2009, 01:03:05 pm »
The factory manual says that with your meter at # 5 & 8 pins and on vDC you should have 0-11.5 v. I know from experience you may not see such a wide range, all you want is the fluctuating voltage. For that test you only have to lift one wheel. spin it forwards or backwards.
February 11, 2009, 11:19:19 pm
madrogers
February 11, 2009, 11:19:19 pm »
thanks , I will try what and see what i have.
mark
Reply #11
February 15, 2009, 09:34:53 pm
madrogers
Reply #11 on:
February 15, 2009, 09:34:53 pm »
I gave up on the factory type setup for now and picked up a aftermarket one from the self serve auto wrecker for 17.00 bucks and it works great .Took about 4 hours to hook it up nice and neat , well worth it for the hwy driveing i do.
Mark.
Reply #12
February 16, 2009, 08:26:07 am
Reply #12 on:
February 16, 2009, 08:26:07 am »
My cruise will engage at 25mpg, not tried anything lower if thats the reply you are looking for at least.
Reply #13
February 16, 2009, 07:50:08 pm
madrogers
Reply #13 on:
February 16, 2009, 07:50:08 pm »
thanks, that helps confirm the speed.
General Information
