Author Topic: How likely is it that i broke an engine mount?  (Read 3916 times)
February 03, 2009, 11:01:52 pm
  • 3468
    • McScrubbins Body Wash
« on: February 03, 2009, 11:01:52 pm »
She's makin 20 psi of boost before the hoses blow off (i have to fix that). It can lay down some SERIOUS rubber....
The mounts are (from what i can tell?) stock... The AAZ head is a little heavier than the 1.6td one...
I can move the engine maybe 1/8th of an inch by leaning on it. Is it time for solid engine mounts?
The 400CI nova i built in school had solid mounts. AND you knew about it  :D
Yes, no? anyone else have solid mounts?
Reply #1February 03, 2009, 11:18:28 pm
madrogers
  • 165
« Reply #1 on: February 03, 2009, 11:18:28 pm »
I can remember the soild mounts on my 69 roadrunner/383/4speed I could not imagin the vibation with a diesel engine, It would shake the whole car apart .
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #2February 03, 2009, 11:22:18 pm
  • 3468
« Reply #2 on: February 03, 2009, 11:22:18 pm »
one could only hope!
It would be excessive yes :P
Reply #3February 04, 2009, 12:02:41 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #3 on: February 04, 2009, 12:02:41 am »
theres the poly insert kit available that fills the voids in the OEM rubber mounts.... this will eliminate a bit of movement and prevent the oem mounts from being overstressed.
'91 Golf Cabrio 1.9TD
Reply #4February 04, 2009, 06:47:57 am
53 willys
« Reply #4 on: February 04, 2009, 06:47:57 am »
put the foot brake on and slowly let the clutch out a little bit and watch the engine to see if it is moving excessively... 8)
Reply #5February 04, 2009, 07:30:35 am
« Reply #5 on: February 04, 2009, 07:30:35 am »
You don't want solid mounts Ed.
Holly crap it vibrates the entire car!!
Ever got for a ride in a car that had an exhaust drone so bad it gave you a headache? That's nothing in comparison to a mk2 with solid mounts.
I had switched to a G60 rubber front mount then I rode in 53 willys car (full hydro) and DAYUM it was nice. Well he has hydro rears and a G60 style front. Anyway, I ran home and swapped in my hydro front again and talk about heaven!
Now keep in mind I just parked my car in-Lu of an 02 Passat with auto trans and heated seats...
Point is the solid mounts are only going to be nice about once a week, the rest of the time you will like the softer mounts.
Reply #6February 04, 2009, 07:44:08 am
arb
« Reply #6 on: February 04, 2009, 07:44:08 am »
Yeah, don't go solid. With that kind of vibration you will be replacing light bulbs too often. Its also a good way to start cracking the spot welds that hold your unibody together.  I had an IDI Jetta in 85' that someone thought the solid mounts would be great on. The passenger side front corner of the body where the right control arm bolts had all of its lower welds broke from this shaking. It was not fun to fix.
Reply #7February 04, 2009, 08:29:59 pm
  • 3468
« Reply #7 on: February 04, 2009, 08:29:59 pm »
I didn't think i'd get such serious replies! I was kidding about solid mounts!!!
I was mostly wondering how much movement was too much.
How do i look at the engine and play the pedals at the same time? :P Do i have to take the hood off again?  :(
Reply #8February 05, 2009, 05:05:27 am
« Reply #8 on: February 05, 2009, 05:05:27 am »
if u offer a few beers, im sure any friend will either work the pedals, or watch the engine. :P
oh btw, go solid mounts, all these guys are crazy they are the bomb! :shock:  :lol:   lol
Reply #9February 05, 2009, 11:54:41 am
ilikevwdiesel
  • 1202
« Reply #9 on: February 05, 2009, 11:54:41 am »
forgive my ignorance but what model VW is it?
My Bio
Reply #10February 05, 2009, 12:39:04 pm
53 willys
« Reply #10 on: February 05, 2009, 12:39:04 pm »
Quote from: "Smokey Eddy"
just open the hood...you can see the engine from the drivers seat just fine...
or get a friend to help...
Reply #11February 05, 2009, 01:10:36 pm
« Reply #11 on: February 05, 2009, 01:10:36 pm »
Quote from: "8v-of-fury"
i'm with you on this one.. i have the passat solid mount in front and will never go back.  that thing will last for LIFE!  no more f***ing around with crap mounts that go after a few years  :lol: (well okay, the front mount can last over 15 years but replacements aren't made of the same quality unless you spend $$$)
i don't really mind the vibration.  it's actually a bit calming!  a person with parkinsons would feel at home in my car  :lol:
Reply #12February 05, 2009, 01:19:07 pm
arb
« Reply #12 on: February 05, 2009, 01:19:07 pm »
Quote from: "jtanguay"
LMAS - Man, that was cold and I feel bad I laughed so hard !!  8-)
Reply #13April 13, 2009, 05:45:34 am
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
« Reply #13 on: April 13, 2009, 05:45:34 am »
hopefully not too OT...  I discovered while my Jetta was up on jacks that I can move the engine in it's mounts by hand - not just a flex, but sort of a tip / clunk.  Am I correct in assuming that it's time for new mounts?
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #14April 13, 2009, 10:49:03 am
« Reply #14 on: April 13, 2009, 10:49:03 am »
about the vibrations..
lol
i can definitely tell when im having diesel withdrawls. when i drive my vw, my hands dont shake. usually my hands always slightly shake. dont know why, its never gotten bad enough to talk to the dr. about. but if i drive my rabbit fairly regularly.. the shaking pretty much goes away. i hope i dont have parkinsons...  :shock:
