Author Topic: Pumps: 1.6td vs 1.6na w/alt comp vs 1.9 aaz td  (Read 3821 times)
February 03, 2009, 05:32:44 pm
hamradio
  • 282
« on: February 03, 2009, 05:32:44 pm »
Ok,
First off, what are the major visual differences between these pumps?
Second, can a 1.6na with alt comp be turned into a td pump?
Third, can a 1.9 aaz td pump work on a 1.6td?
Thanks.
Reply #1February 04, 2009, 03:25:11 am
dillenger1
  • 777
« Reply #1 on: February 04, 2009, 03:25:11 am »
It can be converted over just find the proper fittings to put boost to the lda.The spring needs to be stiffer though,as its very weak.The boost pin diameter is bigger as well so mayube a cummins pin will fit in these.Ive got one converted over,but havent run it yet.I just tapped the little vent thingy on the lda (1/8npt)and threaded a nipple in there,then left the bottom open.You could also grind the pin like i did.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2February 04, 2009, 05:29:55 am
hamradio
  • 282
« Reply #2 on: February 04, 2009, 05:29:55 am »
Ok, thanks!  Awesome info.
Can anyone identify these pumps, from looking at them?
Reply #3February 04, 2009, 09:14:39 am
hamradio
  • 282
« Reply #3 on: February 04, 2009, 09:14:39 am »
Why, here is a pic of the pump tops. 8)
Reply #4February 04, 2009, 09:31:55 am
hamradio
  • 282
« Reply #4 on: February 04, 2009, 09:31:55 am »
On second thought, is that pic worthless for determining things?
Essentially, I'm wondering, can the alt comp pump provide as much fueling as a real td pump?  I have an NA pump right now with a vnt15, and cannot get enough fuel out of it.
Reply #5February 04, 2009, 02:03:43 pm
dillenger1
  • 777
« Reply #5 on: February 04, 2009, 02:03:43 pm »
If the lda has banjo fitting and nipple its a td or is now!
Reply #6February 10, 2009, 04:55:10 am
hamradio
  • 282
« Reply #6 on: February 10, 2009, 04:55:10 am »
I *think* I'm going to spring for the dirtier of the 2 pumps, as it appears to be for sure a 1.6td; it has a cloth covered vac line on the top of the lda, vs a plastic/rubber one on the cleaner one (I'm just speculating, also...I have not actually touched these pumps.  I am also thinking the dirtier shiny greasy one would have been out of the car a shorter period of time than the cleaner less greasy one.
Clean pump
Dirty pump
