Author Topic: Gauges?  (Read 2127 times)
February 02, 2009, 11:21:58 am
gunrtd
  • 31
Gauges?
« on: February 02, 2009, 11:21:58 am »
All of the sudden, the tach and the speedo have gone limp. Completely dead. Happened at the same time so I figure it must be the power feeding the two?
Car is a 95 Jetta.
Any leads?
Reply #1February 02, 2009, 11:25:47 am
arb
Re: Gauges?
« Reply #1 on: February 02, 2009, 11:25:47 am »
Quote from: "gunrtd"
Car is a 95 Jetta.
Any leads?
diesel viagra ?  LOL
The tach is powered from the w lead on the alternator, so separate power.  How are the others on the cluster ?
Reply #2February 02, 2009, 11:45:04 am
gunrtd
  • 31
Gauges?
« Reply #2 on: February 02, 2009, 11:45:04 am »
yeah, the coolant and the fuel work.
Reply #3February 02, 2009, 11:49:26 am
arb
Gauges?
« Reply #3 on: February 02, 2009, 11:49:26 am »
Do you have a bently for the 95' ? Mine is for prior, so I can't trace the 2 gauges you have an issue with..
Reply #4February 02, 2009, 12:19:22 pm
Gauges?
« Reply #4 on: February 02, 2009, 12:19:22 pm »
My '95 gas car had some problems like that when my ground was bad to the engine...
Even though the tach gets its signal from the W terminal, it still gets its power from the same place as the speedo!
Reply #5February 02, 2009, 06:13:52 pm
gunrtd
  • 31
Gauges?
« Reply #5 on: February 02, 2009, 06:13:52 pm »
I figure it's power  -  but I checked all the fuses, and they all look good.
Reply #6February 02, 2009, 07:15:24 pm
Gauges?
« Reply #6 on: February 02, 2009, 07:15:24 pm »
Most likely the cluster has packed it in... simultaneous speedo/tach disappearance is a common failure mode.
Search for "cluster" on the Golf/Jetta III forum on the Vortex and you'll read story after story.
Here's the pinout (sadly, all the wires are the same color :cry: ):
As you can see there's only one supply line (off the ignition switch), so if your other gauges and lights work you know that it's fine.
There *are* two grounds (pins 3 and 5), however, so might be worth checking.  Otherwise, there's probably a junkyard in your future.  :wink:
Reply #7February 03, 2009, 08:55:34 pm
gunrtd
  • 31
Gauges?
« Reply #7 on: February 03, 2009, 08:55:34 pm »
The whole cluster!!!! Looks like I'll keep driving by brail. :(
