Author Topic: best price on "GTD" DNOSD276 or DNOSD274 nozzles??  (Read 4684 times)
January 31, 2009, 08:48:53 am
53 willys
« on: January 31, 2009, 08:48:53 am »
hey guys...I got a spare set of stock injects and I finally have the right fitting to pop test them so I wanna rebuild them with some "GTD" spec nozzles instead of the stock TD nozzles..
any idea who has the best price on FACTORY quality tips/nozzles?? I dont want China tips...... :wink:
Part numbers
DNOSD276
DNOSD274
Thanks to Vince for the part numbers 8)
Reply #1January 31, 2009, 10:20:23 am
GEE-BEE
  • 1604
Nozzles
« Reply #1 on: January 31, 2009, 10:20:23 am »
Kemitdi.com is where I purchased mine
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2January 31, 2009, 10:25:59 am
53 willys
Re: Nozzles
« Reply #2 on: January 31, 2009, 10:25:59 am »
Quote from: "GEE-BEE"
Gee-Bee
why do they have theirs listed as "308" tips??
Reply #3January 31, 2009, 10:38:19 am
Op-Ivy
  • 513
« Reply #3 on: January 31, 2009, 10:38:19 am »
We just had a group buy for nozzles. Good shipping time and Sean is extremely helpful. I give my recommendation. Not sure he has those nozzles but it's worth a try. The nozzles were about $17 each with free shipping! :D
I'm putting mine in today!
If you email him... mention your in Duane's group buy from wisconsin!
http://vwdiesel.net/phpBB/viewtopic.php?t=16804
Reply #4January 31, 2009, 10:41:15 am
53 willys
« Reply #4 on: January 31, 2009, 10:41:15 am »
Quote from: "Op-Ivy"
When you email him...
Quote from: blkboostedtruck
best to call! Sean 1-919-828-5221 mention your in Duane's group buy from wisconsin! (those are the magic words)
I know...I was gonna get some but then I backed out...the timing vs funding was not that great for me..but now i'm thinking it would be nice to get a spare set...
Maybe I will call and see what Sean can do for me?
Reply #5January 31, 2009, 10:44:27 am
53 willys
« Reply #5 on: January 31, 2009, 10:44:27 am »
none of those numbers in the group buy are "GTD" numbers????
293 is stock 1.6TD..(us spec)
that's what I just pulled out of my spares.
Reply #6January 31, 2009, 10:58:49 am
« Reply #6 on: January 31, 2009, 10:58:49 am »
We really really really need someone to find us the secret list of injector specs.... so many nozzles, so little time. ;-)
Reply #7January 31, 2009, 11:00:36 am
Op-Ivy
  • 513
« Reply #7 on: January 31, 2009, 11:00:36 am »
I thought the 293 was stock GTD. That's what I got. Apparently anyway the ratings on the nozzles have very little, if anything to do with the amount of flow.
Initially I was going to go in on the group buy too, but as well, funding was an issue. However, I just bought mine 2 weeks ago so he still accepts people for the group buy.
Reply #8January 31, 2009, 11:05:16 am
53 willys
« Reply #8 on: January 31, 2009, 11:05:16 am »
from what I have been reading 293=stock us spec nozzle..
I too wish there was some good info one way or the other?????
seeing how I am in the us and the injectors came from a us spec engine that the 293 is in fact a stock us spec tip....
Reply #9January 31, 2009, 11:06:38 am
Op-Ivy
  • 513
« Reply #9 on: January 31, 2009, 11:06:38 am »
Vince,
I actually asked Sean about nozzles and their ratings and flow amounts:
The number that relates to the nozzle, in this case 293, is that the amount of flow the nozzle produces? Would a higher number have more flow?
He replied:
"No, in this case the 293 is a design number. The DN 0 SD does tell us indirect injection of a specific size and shape but the makers tend to be less then sharing about what they mean. A number 261 or 265 will allow more fuel through but in a different cone pattern."
Reply #10January 31, 2009, 11:11:30 am
53 willys
« Reply #10 on: January 31, 2009, 11:11:30 am »
I think what I'm going to do is go to my local injection pump shop...I'm pretty good friends with them and I think they can help me find some Higher flow..but still a "safe pattern"....
Monday I'm gonna stop buy..
Reply #11January 31, 2009, 11:23:57 am
blkboostedtruck
  • 1535
« Reply #11 on: January 31, 2009, 11:23:57 am »
Quote from: "Vincent Waldon"
there's no secret list! i tried looking for that with no success! but what i found out was the bigger the # the more fuel and different #'s that were close to each other had to do with atomization of the fuel for emissions!
for example 261 and the 265 were the upgrade! but if you guys call Sean he can explain better then me! he's very help full and the monarch nozzels are nice products! German made can't go wrong there and every one i did work real nice! awesome spray pattern! 308 nozzels are common for the 1.9 motor 297 i would say would be a GTD spec 273 should be common 1.6 nozzels 261 i noticed my motor ran cooler! so any nozzel you can't go wrong they all work! like i said call Sean for better info!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
