Alt. wiring connector
Topic: Alt. wiring connector (Read 1901 times)
January 29, 2009, 03:39:37 pm
boosted_diesel_84
January 29, 2009, 03:39:37 pm »
anyone have a good source for a altenator wiring connector? mine is trashed and i need one, so it does not short to ground against the alt. itself. its the bosch style with the 3 plug, 2 big and 1 smaller. thanks!!
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread
http://www.vwdiesel.net/forum/index.php?topic=15461.0
February 02, 2009, 02:36:43 pm
February 02, 2009, 02:36:43 pm »
Nobody can help the guy? BuMp
February 03, 2009, 09:43:10 am
blkboostedtruck
February 03, 2009, 09:43:10 am »
i got some good used one's just have to splice them in!
P.M. me if interested!
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
