Author Topic: 84 rabbit will not idle.  (Read 28523 times)
Reply #30April 01, 2009, 09:03:33 am
ashleyroe
« Reply #30 on: April 01, 2009, 09:03:33 am »
just got an update from kevin at work at the dealership...
pump timing is off.
didn't say how much or anything else, so we shall see!
Reply #31April 01, 2009, 10:42:36 am
ashleyroe
« Reply #31 on: April 01, 2009, 10:42:36 am »
ALGAE in the fuel tank  :shock:
Reply #32April 01, 2009, 11:49:13 am
ashleyroe
« Reply #32 on: April 01, 2009, 11:49:13 am »
cleaned out the tank. put all new fresh diesel in.
idle issue was solved with adjustment to the pump's timing, still has power issues.
fixed the alternator light issue, the oil light issue too.
everything is in working order now :)
starts up and runs on it's own.
just some more tweaking.
Reply #33April 04, 2009, 04:43:31 am
ashleyroe
« Reply #33 on: April 04, 2009, 04:43:31 am »
new lines, shift linkage, and injectors.
Reply #34April 04, 2009, 07:36:44 am
« Reply #34 on: April 04, 2009, 07:36:44 am »
Now these are some smokin' Women :P:P  Central High-school in Washington D.C 1927
Reply #35April 05, 2009, 04:40:08 am
« Reply #35 on: April 05, 2009, 04:40:08 am »
idle issue was solved with adjustment to the pump's timing, still has power issues       quote
It is a 1.6l n/a right? you will probably always have power issues  :lol: .
Reply #36April 05, 2009, 09:44:29 am
ashleyroe
« Reply #36 on: April 05, 2009, 09:44:29 am »
Quote from: "theman53"
aww  :oops:   :(
haha, no i mean throttle is still messed up, the pedal is still almost at the floor. and there's little pedal travel.
Reply #37April 05, 2009, 10:43:19 am
« Reply #37 on: April 05, 2009, 10:43:19 am »
post pics... of you and the pump  :lol:
With as many pump gurus are around here they will definately be able to help. I would guess that you might need to take arm off and relocate it. I have done that and the only suggestion I have is take pics so you at least know where you can go back to. Oh and try to hold onto the springs, they are sometimes nasty little guys to get back on correctly.
Reply #38April 06, 2009, 06:52:31 am
ashleyroe
« Reply #38 on: April 06, 2009, 06:52:31 am »
they let it run in the lot for 45 mins today...
i got a call that it was smoking ALOT, of blue smoke.
tech says's it's coolant, mayeb the headgasket.
i don't believe it is cause we just put that new one in perfect.
they took it off the bucket of new fuel and they are running it off the tank of old gross fuel right now. i think it's all the crap in the tank burning off.
any opinions?
Reply #39April 06, 2009, 07:23:07 am
« Reply #39 on: April 06, 2009, 07:23:07 am »
Quote from: "ashleyroe"
any opinions?
Blue smoke is not normal and you do not want to be driving behind a truck that produces it. Blue smoke occurs when oil is entering the combustion chamber and is burning along with the fuel. Blue smoke usual indicates a condition which should be corrected a.s.a.p. Blue smoke also smells like oil burning. Possible causes include valve seals or cracked piston rings.
taken from the FAQ here
i doubt its the headgasket.  its possible that the engine's timing is still off, and its blue-white smoke.  my old '86 jetta with mech lifters did this on cold startup.  there wasn't too much of it though.  i would make sure that the engine is getting up to temperature, otherwise the swirl chambers won't be hot enough.   when i installed a 160F t-stat in my 1.6TD, it would smoke quite a bit more than when i installed the 192F t-stat.
Reply #40April 06, 2009, 01:18:25 pm
ashleyroe
« Reply #40 on: April 06, 2009, 01:18:25 pm »
engine's timing is perfect. it's been perfect since we did it in the garage.
just the pump was off. i think it was at liek .38 or something ridiculous.
it's set to .93 now.
it's constant smoke, and alot.
the smoking got worse the longer it ran.
i haven't seen it yet but they are finishing it up and i'm just gonna drive it.
we thought maybe it was coolant in the exhaust from when the HG blew the first time, but it would have all burned off by now.
they'ev been driving it and said it runs great and idles perfect. so who knows what's up with it.
Reply #41April 06, 2009, 03:49:59 pm
« Reply #41 on: April 06, 2009, 03:49:59 pm »
If coolant got into the exhaust it will take a long time to burn it out of the muffler. Blue smoke is sometimes oil burning or really rich condition. If it runs good and idles well I would just run the crap out of it and see what happens. If something major is wrong like a headgasket then it will show up either way.
Old fuel could act very badly as well. You should get rid of that and run some good into it. Keep a couple fuel filters and replace them after a tank or 3 and that should clear it up. Maybe an injector has some of the algea junk in it and sticking open a little? Seafoam and diesel purge can help as well as ATF.
Reply #42April 06, 2009, 03:50:02 pm
ashleyroe
« Reply #42 on: April 06, 2009, 03:50:02 pm »
well, i saw the car run today in person.
there's not much smoke at all. i'm not sure what they were talking about.
on rev's it pumps out a cloud of blackish dark grey smoke.
the idle bounces until the car warms up and then idles fine.
it also has a fairly hard time starting.
more clues for this mistery.
should i just put in a new IP?
Reply #43April 06, 2009, 03:51:35 pm
ashleyroe
« Reply #43 on: April 06, 2009, 03:51:35 pm »
yeah i am just gonna drive it.
i think it's all teh bad fuel, but their pump to take teh fuel out at the dealer is broken.
thanks for the help.
i need to buy some more fuel filters  :roll:
Reply #44April 06, 2009, 07:57:03 pm
« Reply #44 on: April 06, 2009, 07:57:03 pm »
this sounds like every NA that I have had. I would run it as long as I could and then see MR.Giles in the vendor forum for an IP if you ever need it. The more you run this the better it should get. I would run some sort of cleaner in the fuel filter when you change it and some in the tank as well until things get worked out.
