Author Topic: Downpipe Theory, It can't be too big, Right?  (Read 6759 times)
January 13, 2009, 09:21:17 pm
AudiVWguy
« on: January 13, 2009, 09:21:17 pm »
Soon I will be swapping the current turbo with a IHI Ball Bearing Turbo. I've got to custom make the down pipe again. What if the DP came out of the turbo at 3in. and then immediately went to 4in till it went down and under the car to the flex coupler then back to 3in.
This allows the hot expanded gasses to get past the turbo, then start to cool and contract on its way toward the smaller rest of the exhaust.
Does this sound reasonable, or do I just stay with the 2.5in?
I would think that even though the size of the exhaust won't be consistent, the most important part is the first 18in after the turbo.
I'm just not sure if the giant PITA is worth the benefit.
Any Thoughts??
Reply #1January 13, 2009, 09:50:53 pm
Christian_Finland
  • 23
« Reply #1 on: January 13, 2009, 09:50:53 pm »
Go for the 3" down pipe but make sure there isn't any sharp edges on the turbo outlet to the down pipe to avoid any unwanted turbulens.
Here's a pic of my 3" DP.
Seat Toledo -97 1.9TDi (AHU, KKK K26 turbo, EVO 3 LT intake manifold, Big FMIC, ASV 110hp nozzles, custom software, 3" downpipe and exhaust, 3" turbo intake pipe, 2.5" IC pipes) daily and VW Jetta -89 project
Reply #2January 13, 2009, 09:58:46 pm
« Reply #2 on: January 13, 2009, 09:58:46 pm »
3" is probably the biggest for these motors.  bigger on a diesel is always better, but mounting a 4" pipe would be very difficult.
gassers need to limit the size of the exhaust for vacuum purposes, etc.
Reply #3January 13, 2009, 10:06:03 pm
Christian_Finland
  • 23
« Reply #3 on: January 13, 2009, 10:06:03 pm »
Quote from: "jtanguay"
In a gasser turbo engine it's the same deal as in diesel turbo engine. Anything restrictive after the turbo is bad for the EMP's.
Reply #4January 13, 2009, 10:35:09 pm
« Reply #4 on: January 13, 2009, 10:35:09 pm »
Quote from: "Christian_Finland"
on a turbo gasser yes, because the turbo acts as a restriction.
Reply #5January 14, 2009, 12:48:38 am
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: January 14, 2009, 12:48:38 am »
Biggest you could go would be no down pipe and exhaust at all.
You you don't like that idea i'd suggest a 6 inch (or bigger?) down pipe that comes through the hood like a zoomy.
Reply #6January 14, 2009, 09:46:12 am
AudiVWguy
« Reply #6 on: January 14, 2009, 09:46:12 am »
I was thinking of creating a buffer area that the exhaust pressure would have to condense and then continue thru the exhaust system. Remember how the 2-stroke motorcycle exhaust had "expansion chamber" design for the exhaust pipe. I was thinking along those lines.
Reply #7January 14, 2009, 01:08:08 pm
saurkraut
  • 904
« Reply #7 on: January 14, 2009, 01:08:08 pm »
Quote from: "AudiVWguy"
I used to race super mod two stokes, so I know probably way too much about expansion chambers.
An Expansion chamber is a sonic supercharger for two stroke gas engines.  With out going into the whole detail of their opperation, the pipe  accutually creats a vaccum that pulls fuel air mixture out of the cylinder/crankcase and into the pipe.  Meanwhile, the blast from the exhast port reaches the rear cone of the chamber, and a sonic wave is reflected back up the pipe, pushing the fuel air mixture back into the cylinder as the piston closes the port.
In summerey, none of that stuff applies to your engine.
Upon causal inspection, there's a Wiki article that provides a good explanation: http://en.wikipedia.org/wiki/Expansion_chamber
Lots of stuff going on in one of those pipes :wink:
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #8January 14, 2009, 06:44:18 pm
AudiVWguy
« Reply #8 on: January 14, 2009, 06:44:18 pm »
OK,
I guess that was a bad example. I guess that somebody out there who's modding the Dodge and Ford stuff would have something out there by now if there were an advantage to varying the size of the down pipe.
