Author Topic: WTB: Diesel Vanagon choke cable/ housing  (Read 4323 times)
January 13, 2009, 12:24:49 pm
wildenbeast
  • 50
    • The WILDENBEAST
« on: January 13, 2009, 12:24:49 pm »
I am looking for the choke cable assembly that came stock on many of the diesel vanagons. I am looking for the cable, housing, cold start lever etc. On diesel vanagons, there is a cold start lever like a choke that needs to pulled out to start the engine and then pushed back in once the engine is running. It is connected to the pull-out handle on the RH side below the steering wheel on an '87 diesel Westy. This is what I am looking for. Thanks.
Bill
303.775.5524
1990 Syncro Adventurewagen
1.9 Turbo Diesel (AAZ)
http://billwildenberg.shutterfly.com/vwvanagon
Reply #1January 13, 2009, 03:16:10 pm
Quantum TD
  • 1195
« Reply #1 on: January 13, 2009, 03:16:10 pm »
That might be a tough order, unless our friends to the north can help out.
Check out the VAGCAT listing with image and part numbers:
http://www.vagcat.com/epc/cat/vw/T2/1982/4/55/59132/
YOu'll need to create an account to see the images and part numbers.
It looks like the dealers in the US MIGHT be able to get them (at a cost of about $50 just for the cable). Then you'd need the knob, washers, clips, etc.
Good luck
Reply #2January 13, 2009, 03:28:10 pm
Quantum TD
  • 1195
« Reply #2 on: January 13, 2009, 03:28:10 pm »
Here's a list of the parts if you can't find a setup, with prices from 1stvwparts.com. They may list the part as available, but that doesn't always mean it's actually available.
Quantity/Part Number/Desription/Price
1       321711510         Bushing         $0.68
1       N 0115608          Washer         $0.19
1       N 0115641          Washer         $2.04
1       861711509          Shoulderd Nut      $8.15
1      111941541B 043    Knob         $8.16
1       171971913         Grommet         $1.30 each
1       251711501b        Cable         $59.00
OR
1       251711501A        Cable         $66.00
Reply #3January 16, 2009, 01:39:51 pm
wildenbeast
  • 50
    • The WILDENBEAST
« Reply #3 on: January 16, 2009, 01:39:51 pm »
Thanks for the help (especially the part numbers)!
