Author Topic: WTB - Boost pin  (Read 3996 times)
January 12, 2009, 06:01:36 am
ein bora
  • 377
WTB - Boost pin
« on: January 12, 2009, 06:01:36 am »
no longer needed
If you can't take advice - then you can't be helped!
Reply #1January 12, 2009, 01:43:30 pm
syncroparge
  • 1
WTB - Boost pin
« Reply #1 on: January 12, 2009, 01:43:30 pm »
newbielink:http://www.brickwerks.co.uk/index.php?option=com_virtuemart&page=shop.browse&category_id=96&Itemid=6 [nonactive]
Try this place he ships worldwide...
Reply #2January 12, 2009, 01:53:14 pm
ein bora
  • 377
WTB - Boost pin
« Reply #2 on: January 12, 2009, 01:53:14 pm »
Quote from: "syncroparge"
Thanks - appreciate the help!
Wrong spot I know - but do I still need the diaphragm or can I use the existing one on the AAZ??
Reply #3January 20, 2009, 10:12:11 pm
Clintwalker85
  • 91
WTB - Boost pin
« Reply #3 on: January 20, 2009, 10:12:11 pm »
i want to do the same swap...also i need to know if you can use a aaz diaphram????
Reply #4January 21, 2009, 07:39:27 am
WTB - Boost pin
« Reply #4 on: January 21, 2009, 07:39:27 am »
I dont know why you couldnt reuse the same diaphram.
Reply #5January 21, 2009, 07:24:31 pm
GEE-BEE
  • 1604
pin
« Reply #5 on: January 21, 2009, 07:24:31 pm »
I ordered a pin and a gasket
Great service and fast reply to my order  :D
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
