Author Topic: Engine Stalls While Driving  (Read 3880 times)
January 07, 2009, 05:57:01 am
bassmun
« on: January 07, 2009, 05:57:01 am »
So, the past couple days I have been driving my '91 Jetta just cruisin' along at decent speed and it will just cut out on me. I have to pull over and start up again. Than today it did this again but the radio also cut out twice. I am totally baffled. Is this a mechanical thing or an electrical thing?
Reply #1January 07, 2009, 07:34:54 am
Op-Ivy
  • 513
« Reply #1 on: January 07, 2009, 07:34:54 am »
Was the radio cutting out at the same time as the engine? I think you should take a look at your connections to your battery and work from there.
Reply #2January 07, 2009, 07:46:50 am
bassmun
« Reply #2 on: January 07, 2009, 07:46:50 am »
Quote from: "Op-Ivy"
No, the radio was not cutting out at the same time as the car. I think that is actually due to a loose fuse tap now that I think about it. I will however check the battery cables and see if they are nice and tight.
Reply #3January 07, 2009, 10:01:15 am
Quantum TD
  • 1195
« Reply #3 on: January 07, 2009, 10:01:15 am »
1) loose fuse screws
2) bad connection on fuel stop solenoid
3) clogged filter
Reply #4January 07, 2009, 10:12:23 am
bassmun
« Reply #4 on: January 07, 2009, 10:12:23 am »
Quote from: "Quantum TD"
3) clogged filter
I have to apologize for being a little ignorant about this car. Where would I find the "fuel stop solenoid"?
Reply #5January 07, 2009, 02:01:13 pm
Quantum TD
  • 1195
« Reply #5 on: January 07, 2009, 02:01:13 pm »
The stop solenoid is a round switch with a large nex-nut base that screws into the driver's side of the injection pump, in the cast-iron part of the pump where the fuel lines come out. It has a single (usually black or blue) wire that connects to the top of it (either thru a spade terminal, or a single 8mm nut).
When the ignition is on, the solenoid is energized, and allows fuel to flow throught the pump. If there is a bad connection on it, it will cut off the fuel. There are a few stories here of people with loose or broken wires (that have grounded out while the car was running), and they had similar symptoms that you have.
Otherwise, it could be the ignition switch, or a clogged fuel filter.
