Author Topic: what is the comp ratio?  (Read 2789 times)
January 06, 2009, 12:55:11 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« on: January 06, 2009, 12:55:11 pm »
what is the compression ratio for a 1.6td mf?
I am curious but i can't find the number?
If someone just pm's me i'll delete this post. It's kind of useless.
Ed
Reply #1January 06, 2009, 01:15:30 pm
TurboJ
  • 661
« Reply #1 on: January 06, 2009, 01:15:30 pm »
23.0 : 1
I don't think it's useless - you can't find that too easily on the net
Jetta II 1.6 TD 'Project 200'
Reply #2January 06, 2009, 01:16:27 pm
Smokey Eddy
  • 3468
« Reply #2 on: January 06, 2009, 01:16:27 pm »
sweet thanks TurboJ!
Ed
Reply #3January 06, 2009, 01:31:55 pm
shegel
  • 312
« Reply #3 on: January 06, 2009, 01:31:55 pm »
i thought the turbo cars were 17:1 instead of the 23:1 like the n/a cars
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #4January 06, 2009, 01:36:30 pm
TurboJ
  • 661
« Reply #4 on: January 06, 2009, 01:36:30 pm »
Nope..  Engines are identical apart from the piston oil squirters the TD has.
Reply #5January 06, 2009, 02:30:40 pm
  • 3255
    • My collection of HOWTOs
« Reply #5 on: January 06, 2009, 02:30:40 pm »
Quote from: "shegel"
I've heard this thought before from other people as well... I wonder if it partly comes from the world of gasser engines where it's common to reduce the compression ratio when adding a turbo to reduce the chances of detonation?
In any event, diesels don't have that same concern and so there's no real reason for the compression ratio to change when you add a turbo... bring it on!!!
Reply #6January 06, 2009, 02:47:23 pm
shegel
  • 312
« Reply #6 on: January 06, 2009, 02:47:23 pm »
Quote from: "TurboJ"
dont forget that the actual pistons are notched so they dont hit the squirters
Reply #7January 06, 2009, 04:28:31 pm
TurboJ
  • 661
« Reply #7 on: January 06, 2009, 04:28:31 pm »
Good point.
Also, about the compression ratio. Many IDI and TDI engines do indeed have lowered compression ratio when a turbo version is made. Even some VAG diesel engines do. Personally I have always wondered why they didn't do it with the 1.6 TD. Maybe because of the relatively low output they didn't feel the need. If only they had known what enthusiasts will be doing to those engines in 20-years time....
Reply #8January 07, 2009, 07:40:34 am
Sprockets
  • 29
« Reply #8 on: January 07, 2009, 07:40:34 am »
Indeed, the high CR's are due to getting the damn things going! a CR of 23:1 is FAR from optimal, I believe the best is in the 15:1 range.  I did do some research into this a while back and it made some fascinating reading.  I'd advise the curious to plunge some key words into google and have a little look.  I'm not going to comment much further as it was a while ago I did all this, and I can't be 100% sure of my facts, so I don't want to tell people wrong information :)
-Gavin
