Author Topic: Another Injector Pop Tester DIY  (Read 44962 times)
January 05, 2009, 10:10:49 pm
Op-Ivy
  • 513
« on: January 05, 2009, 10:10:49 pm »
So I finally decided to build a pop tester. I've been wanting to replace the nozzles for a while.They are still the originals!!!  :shock:
I took some pictures while making it so I thought I would share them. There are a couple good DIY's on the forum right now but another one will help clarify things a bit.
Nearly all of the parts, minus the injector line that was bought from Vincent Waldon, were purchased at princess auto.
Materials used:
2ton Bottle Jack
0-3500PSI Gauge
Steel hydraulic fittings rated at 5000 psi
Here you can see the entire contraption laid out. Note that I had to use two adaptors, one from the injector line to an awkward thread type I can't remember the name of, and then another one to NPTF.
Bottle jack with the safety release hole welded shut. This is the hole that prevents the ram from overextending.
Metal plate with fitting tapped into it.
Again.
Initial weld of plate and fitting.
Pop tester completed. I ended up having to really load on the welding wire. At first I had a few "weeps" of fuel coming out. Works great now!
Hope this helps anyone else thinking about making one. Not shown is the steel plate shield I made to prevent injury in case of any failure of parts.
If anyone has any questions, feel free to ask! :)
Matt
Reply #1January 05, 2009, 11:59:20 pm
Op-Ivy
  • 513
« Reply #1 on: January 05, 2009, 11:59:20 pm »
Yes. Unfortunately I was limited to a 120v flux core welder.
Reply #2January 06, 2009, 12:37:50 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: January 06, 2009, 12:37:50 am »
sweet sauce im definitely doing this!
do you have a rough total cost?
Ed
Reply #3January 06, 2009, 07:27:37 am
Op-Ivy
  • 513
« Reply #3 on: January 06, 2009, 07:27:37 am »
Total cost minus welding wire which would be too hard to calculate would be about $50.
Time to build was an afternoon and a bit after dinner.
Reply #4January 06, 2009, 08:53:12 am
blkboostedtruck
  • 1535
« Reply #4 on: January 06, 2009, 08:53:12 am »
Quote from: "Op-Ivy"
you should of sent it to me to weld i could of made it look like a 400dollar weld! :D  oh well next time! a bigger gage is always better like a big 5" round gage with lots of marks for finer adjusting! you got shims?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #5January 06, 2009, 09:43:21 am
moise
  • 734
« Reply #5 on: January 06, 2009, 09:43:21 am »
 :wink:
Reply #6January 06, 2009, 01:00:49 pm
Smokey Eddy
  • 3468
« Reply #6 on: January 06, 2009, 01:00:49 pm »
jesus christ that's a grease gun?
Ed
Reply #7January 06, 2009, 01:32:08 pm
moise
  • 734
« Reply #7 on: January 06, 2009, 01:32:08 pm »
yes, i agree, it's not mine, it 's a exemple :wink:
Reply #8January 06, 2009, 02:38:41 pm
  • 3255
    • My collection of HOWTOs
« Reply #8 on: January 06, 2009, 02:38:41 pm »
Great job... of course I think the injector hard line is the best part, but that's just me ;-)
One thing I did before I filled it the first time was drill four mounting holes in the base so that I could screw it into the workbench.  It actually takes a bit of handle pressure to generate 155 bar and I discovered having the thing securely fastened down was as simple as some #12 wood screws thru some freshly-drilled mounting holes.
On a related note.... I made the mistake of prematurely shortening the handle (to save workbench space) ("how tough can this be") and I now have to reef on mine pretty good to generate pressure.  Or perhaps I'm just a wimp. :wink:
Reply #9January 06, 2009, 05:33:52 pm
cyrus #1
  • 360
« Reply #9 on: January 06, 2009, 05:33:52 pm »
Nicely done Matt!  I look forward to putting it to use.  :twisted:
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
1990 Jetta 8v-Eventually to be 1.6TD
Reply #10January 06, 2009, 06:53:31 pm
« Reply #10 on: January 06, 2009, 06:53:31 pm »
make sure to use it slowly when nearing the breaking pressure for better accuracy  :wink:  the longer the high pressure line, the more inaccurate result if you don't do it slowly.
good setup!
Reply #11January 06, 2009, 09:48:54 pm
Op-Ivy
  • 513
« Reply #11 on: January 06, 2009, 09:48:54 pm »
Thanks for the tip Vince! I actually just clamped it down to the workbench with a C clamp for the time being, but thats a good idea.
Dwayne, I still haven't contacted the group buy vendor for nozzles yet. Just waiting for paypal to receive my deposit. But yes I will need shims and heat shields.
Reply #12January 26, 2009, 03:53:24 am
Turbinepowered
  • 1206
« Reply #12 on: January 26, 2009, 03:53:24 am »
Anyone figured out a good source for big gauges? Maybe even ones in Bar? :D
Reply #13January 26, 2009, 08:43:27 am
dieselherb1
  • 354
« Reply #13 on: January 26, 2009, 08:43:27 am »
Surpluscenter.com
Reply #14February 24, 2009, 08:16:23 am
anto
« Reply #14 on: February 24, 2009, 08:16:23 am »
Where does the diesel enter this system?
Any pics showing that?
