Author Topic: scirocco 1.6 SB to AAZ 1.9...  (Read 4259 times)
January 05, 2009, 11:20:18 am
MouseGTD
  • 110
« on: January 05, 2009, 11:20:18 am »
i have a 1.6 GTD set up in my mk2 scirocco but its had its day, i've just picked up a seat toledo that has a 1.9td AAZ in it. what will i have to do to fit it into my car? i'm assuming i'd have to fit a mk1 golf driver side engine mount but what else would i need to do to fit it into the GTD set up? would my drive shafts bolt onto the AAZ gear box?
Reply #1January 05, 2009, 01:32:33 pm
Baxter
« Reply #1 on: January 05, 2009, 01:32:33 pm »
Swap the engine, leave the box alone?
No issues then!
Inlet manifold ports are different too remember, so use the 1.9 inlet.
Reply #2January 05, 2009, 02:08:15 pm
MouseGTD
  • 110
« Reply #2 on: January 05, 2009, 02:08:15 pm »
i was gonna just swap the whole lot over (intake, out take and every thing else attached to it, if i have to keep my box i will but its not very healthy tbh and the one on the AAZ has a lot less miles on it and is very smooth. so can i swap to this box or do i have to keep mine?
Reply #3January 06, 2009, 10:53:29 am
bert
  • 423
« Reply #3 on: January 06, 2009, 10:53:29 am »
my aaz to mk1 was a case of using the old box 5 speed dfw code,with the 90mm flanges,the aaz box if it is a chd code box has 100mm flanges,so more involved,i used a T3 off a 1.6td and the car really does go well,ive got 112bhp 159lbft torque  :wink:
Bert
Reply #4January 06, 2009, 01:41:55 pm
MouseGTD
  • 110
« Reply #4 on: January 06, 2009, 01:41:55 pm »
but surely the 90 and 100mm refers to the ends of the drive shaft that goes into the wheel hub not on to the gearbox? i just need to know if my gtd drive shafts will bolt up to the gearbox on the AAZ?
Reply #5January 06, 2009, 11:13:36 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: January 06, 2009, 11:13:36 pm »
pics of rocco or you dont have one...
Reply #6January 06, 2009, 11:52:38 pm
bert
  • 423
« Reply #6 on: January 06, 2009, 11:52:38 pm »
no its the size of the drive flanges on the gearbox
Bert
Reply #7January 07, 2009, 01:18:22 pm
MouseGTD
  • 110
« Reply #7 on: January 07, 2009, 01:18:22 pm »
Quote from: "vanagonturbo"
why would i lie? lol
