Author Topic: SO...how much power is this setup probably producing?  (Read 2193 times)
January 01, 2009, 09:09:45 pm
hamradio
  • 282
« on: January 01, 2009, 09:09:45 pm »
1.6 NA converted to TD.
NA injectors.
NA pump cranked way up.
VNT 15 doing 15 PSI
No intercooler.
We'll say timing is good.
Any ideas?  60 bhp/75 ft/lb?
Additionally, what would an alright intercooler, a turbo pump, and some turbo or mercedes injectors bump things up to?
Thanks.
Just getting excited about driving my car next summer, and throwing it on a dyno.
Reply #1January 01, 2009, 10:14:42 pm
TurboJ
  • 661
« Reply #1 on: January 01, 2009, 10:14:42 pm »
Well, the N/A pump has a bigger head than the Eco-TD's. (9 mm versus 8 mm IIRC)
And you're running considerably more boost (1 bar compared to 0.65 bar) than the Eco TD, so you should be comfortably past the Eco-TD's 60 hp.
I would guess 75 or so hp.
Probably not much more than that though without an intercooler.
Jetta II 1.6 TD 'Project 200'
Reply #2January 02, 2009, 03:45:01 am
TurboJ
  • 661
« Reply #2 on: January 02, 2009, 03:45:01 am »
Quote from: "libbybapa"
The ECO TD was 57hp.
Andrew
Yeah, I had an error in there.. fixed now
Here are the correct numbers as far as the European spec models are concerned:
1.6 D  (n/a)  40 kW (54 hp)  and  100 Nm @2300-2900
1.6 Eco-TD   44 kW (60 hp)  and  110 Nm @2400
1.6 TD         51 kW (70 hp)  and  133 Nm @2500-2900
1.6 TD I/C   59 kW (80 hp)  and  155 Nm @ 2700
Reply #3January 02, 2009, 10:41:05 am
« Reply #3 on: January 02, 2009, 10:41:05 am »
i think these clutches can hold 120hp semi-reliably (not slipping the clutch all the time) so if your car can't slip the clutch, then you're doing near or below 120hp.  my best guess would be about 90-100hp max though... the torque however will be much more due to the low boost of the VNT.  i would say torque is more in the range of 120ft/lbs or even 140ft/lbs.
does it smoke much at low rpm's??? that turbo must spool up instantly... you might not even need a true TD pump.  just a tweaked NA pump to deliver loads of fuel.
Reply #4January 02, 2009, 06:05:02 pm
  • 2932
« Reply #4 on: January 02, 2009, 06:05:02 pm »
I don't think you need a turbo pump,...
 it only keeps the smoke down before boost, you can do that with your foot.
 Probably close to 80 horses.
There was a formula I learned in physics class for finding your horsepower.
 Had to go from 20-30, 30-40, 40-50 etc.
 Then 50-40, 40-30, 30-20.
 subract the difference, weigh your car, etc.
 When I was checking the HP in my 79 Civic a cop pulled me over and asked what I was doing tearing up and down the road.
 I showed him my results and proclaimed a trusty 37HP? (or something close to that) at the wheels. :D
 No ticket.
 I think he felt sorry for me; 37HP at the wheels sheesh, your suffering enough already.
  Or pictured himself trying to convince a judge to convict me of excessive acceleration. 37HP???? really????  :D
 I'll see if I can find the formula.
