General Information
Troubleshooting
How to find model number on engine ?
Topic: How to find model number on engine ? (Read 4773 times)
December 30, 2008, 11:51:37 am
AndrewSE
December 30, 2008, 11:51:37 am »
I seem to be having trouble finding the model of the engine in my 91 jetta.
Where on the engine is the id code ?
thankz
December 30, 2008, 12:31:01 pm
cyrus #1
December 30, 2008, 12:31:01 pm »
There is a flat spot at the top of the block, where it meets the head. It will be between cylinders 2 and 3. It's probably covered in grease. :lol:
1.6 NA should be ME
1.6 TD should be MF
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
1990 Jetta 8v-Eventually to be 1.6TD
December 30, 2008, 01:45:23 pm
AndrewSE
December 30, 2008, 01:45:23 pm »
cool stuff ! thankz for the reply.
what would a 1.9 TD be?
Its been mentioned that mine looks to be a 1.9 TD from pics I've posted.
just need to make sure so I can order my turbo oil feed line from the stealer and not get the wrong one.
thankz
December 30, 2008, 02:06:33 pm
cyrus #1
December 30, 2008, 02:06:33 pm »
You should add your location to your profile. It will help us give you more informed answers!
A 1.9TD would most likely be an AAZ. On this side of the pond at least.
Cody
2002 Jetta TDI
December 30, 2008, 02:22:25 pm
AndrewSE
December 30, 2008, 02:22:25 pm »
ok good stuff thankz !
In Canada as well.. Toronto area.
December 30, 2008, 04:43:21 pm
December 30, 2008, 04:43:21 pm »
A standard Canadian 1991 Jetta will have a 1.6l MF engine rather than the 1.9l AAZ... and the lines are definitely different, so you'll want to be sure.... dealers rarely do refunds. :wink:
Easiest way, short of finding the cryptic part number on the block, is to see how the valve cover bolts down. If it's held down with 8 bolts around the perimeter of the valve cover it's a 1.6... if there are 3 bolts in the top of the valve cover it's a 1.9.
If you can direct us to a picture or two we can probably give you the Internet's opinion. :lol:
January 02, 2009, 10:49:41 am
AndrewSE
January 02, 2009, 10:49:41 am »
My pictures are in the thread below.
http://vwdiesel.net/phpBB/viewtopic.php?t=16551&start=0
I have since cleaned my engine since these pictures....
Looks to be a 1.9 based on your explanation.
Thankz for the help.
General Information
Troubleshooting
