Author Topic: Block Steam Holes!  (Read 4989 times)
December 29, 2008, 10:46:01 pm
  • 3468
    • McScrubbins Body Wash
Block Steam Holes!
« on: December 29, 2008, 10:46:01 pm »
Is it ok if the steam holes on the block don't line up EXACTLY to the head gasket?
One of my holes i drilled today is slightly covered with the HG. I know the other coolant passages are blocked by the head gasket but they have crush-retainers. I can only hope it's the same story for the steam holes
I should have used a smaller bit i know.  :(  But as far as i know this is okay. I just want to check with you fellas.
Reply #1December 31, 2008, 10:28:51 am
Block Steam Holes!
« Reply #1 on: December 31, 2008, 10:28:51 am »
I don't think it would be to much of a problem really.
I doubt mine are exactly lined up now that I think about it.
I just used the HG as a template and I doubt I was able to place it in the exact same place on both the block and the head. Their close for sure but....
Reply #2December 31, 2008, 02:26:22 pm
  • 3468
Block Steam Holes!
« Reply #2 on: December 31, 2008, 02:26:22 pm »
ah ok
that's reassuring.
I figured it wouldn't be a problem because the coolant holes are blocked by the head gasket... like by a lot.... they go from tear drop to circle
