Author Topic: Pump trouble!!!! help plz  (Read 1890 times)
December 19, 2008, 08:49:23 am
phaetonv10
  • 83
« on: December 19, 2008, 08:49:23 am »
hey guys... i have a 1.6d NA, ME engine code..... and it has been giving me trouble....
the main issue is that idle is not stable.... the revs keep varying while it is idling....
and the second issue is that whenever i rev it in any gear and press the clutch, it shuts down and takes 2 or 3 turns of the key to start.....
i think the problem is with the pump because i changed the pump recently and the varying revs at idle problem started only with the new pump, and while the shutting down after high revs problem used to happen before as well, sometimes that is....
THE LEMON
1.6 GTD, FMIC, ARP Studs, Brembo brakes, Power Clutch, ibiza tdi twin fan setup, Racing Seats, 40 mm all aluminium radiator, audiophile music.
Reply #1December 19, 2008, 08:52:47 am
SMOKEYDUB
  • 630
« Reply #1 on: December 19, 2008, 08:52:47 am »
the pump is sucking large amounts of air in from one of the fuel lines i believe.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
