Author Topic: TD Pop Pressure Variants?  (Read 2610 times)
December 14, 2008, 11:43:03 am
ObscuredByClouds
  • 98
« on: December 14, 2008, 11:43:03 am »
I took apart my nozzles to put new smog ones in, and there was 130bar stamped in it. N/A nozzles? I have another TD engine and that had 130bar as well, makes me think there are some factory equipped 130bar TD's.
What do you think?
Reply #1December 14, 2008, 10:35:28 pm
AudiVWguy
« Reply #1 on: December 14, 2008, 10:35:28 pm »
That's just what the housing says. Gotta pop test'em.
I wonder, can ya run the motor on three cyl and take the remaining injector line to look at the injector spray pattern?
Reply #2December 15, 2008, 12:04:21 am
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: December 15, 2008, 12:04:21 am »
you can turn the lines all upside down, crank it over and look at the spray on all four.
OR if you have the belt off anyways - turn the pump with a ratchet. (make sure you don't turn it the wrong way (ie. to undo the bolt/nut)
An impact gun would work well.
Reply #3December 15, 2008, 04:50:26 am
« Reply #3 on: December 15, 2008, 04:50:26 am »
Quote from: "Smokey Eddy"
ya do the upside down method and have someone crank for you, but just stay a good distance away from the injector.
Reply #4December 15, 2008, 07:07:30 pm
« Reply #4 on: December 15, 2008, 07:07:30 pm »
Quote from: "jtanguay"
That's not going to tell you the opening pressure though
Reply #5December 15, 2008, 07:49:59 pm
blkboostedtruck
  • 1535
« Reply #5 on: December 15, 2008, 07:49:59 pm »
thats just a dangerous idea in general!
i can just pop test 4 injectors for 10bucks if you guys wanna know where your's are popping at? giving you bad news is free!
Duane  :shock:
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #6December 15, 2008, 10:42:42 pm
« Reply #6 on: December 15, 2008, 10:42:42 pm »
I tried that when I did my compression test the other day, doesn't work. The upper rad hose is directly in the way of #2 injector. Actually the injector line hits the underside of the rad hose so you'd have to loosen rad mounts, kink the hose sharply to the side and when you stop holding the rad hose it would pop back and wipe out the injector line :roll: I guess if you had a different hose configuration it might work. :)
Reply #7December 16, 2008, 01:24:21 pm
Turbinepowered
  • 1206
« Reply #7 on: December 16, 2008, 01:24:21 pm »
Quote from: "rabbitman"
If you guys had your engines turned the right way, you wouldn't have these problems. ;)
No such interference in a longitudinal Fox application.
