Author Topic: WTD: UK-BASED GTD PARTS  (Read 3744 times)
December 12, 2008, 07:32:10 am
JB!
  • 6
« on: December 12, 2008, 07:32:10 am »
hi guys.
need the following bits here in the UK.
Oil cooler
turbo oil feed pipe
oil pipes (all of the rubber ones)
oil filter
front engine mount
any retaining clips needed on oil/water pipes
Radiator
top rad hose
bottom rad hose
any other rubber water hoses
thermostat
in-line water pump
belt driven water pump
header tank
i know some of this it is better to get new, but if your breaking a GTD, let me know i probably need more than i have listed here!
thanks!
Reply #1December 12, 2008, 02:55:21 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #1 on: December 12, 2008, 02:55:21 pm »
Oil cooler - same as a gti.
turbo oil feed pipe
oil filter - mann filter from GSF don't bodge with a gasser one.
front engine mount - usual Mk2 hydraulic mount, fleabay?
Radiator
top rad hose
bottom rad hose
thermostat
in-line water pump - also used on some VR6's
header tank - most late mk2's have something similar.
Here is a good link for cross referencing bits, Later Mk2 GTD engine codes are RA and SB.
http://www.vagcat.com/
Some late Mk2 passats also used these motors.
 8) Happy Hunting.
