Author Topic: Turbo head part number  (Read 3842 times)
December 11, 2008, 09:25:16 am
Greasecar
  • 126
    • http://www.greasecar.com
« on: December 11, 2008, 09:25:16 am »
I'm going through my pile of old parts to see what I have and what I'm missing to put together a 1.6 TD motor.  I have a TD block and a number of heads on the shelf, I'm pretty sure I have at least one turbo head but I can't remember what part numbers differentiate the turbo and NA heads.  Can anyone help.  One of the heads appears to have the turbo exhaust valves but I want to be sure.
Thanks
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
Reply #1December 11, 2008, 09:41:56 am
arb
« Reply #1 on: December 11, 2008, 09:41:56 am »
The heads are the same, the blocks and many other parts are different.
YIKES !!!  I was mistake - listen to _that_ guy...
Reply #2December 11, 2008, 10:26:36 am
« Reply #2 on: December 11, 2008, 10:26:36 am »
Quote from: "arb"
OH SNAP!!!!   :lol:
No they are not the same!!!
The heads are made of different materials and different exhaust valves.
There are threads here with the exact info but I'm not searching for it..
That's right, I'm lazy  :?
Reply #3December 11, 2008, 11:30:01 am
blkboostedtruck
  • 1535
« Reply #3 on: December 11, 2008, 11:30:01 am »
yep Dan's right they are not the same
made with superior materials to handle the extra heat and compression!
it's written in the turbo diesel write up by the factory!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #4December 11, 2008, 12:40:40 pm
« Reply #4 on: December 11, 2008, 12:40:40 pm »
Quote from: "libbybapa"
the diameter of the pre-chambers on the TD engines is slightly smaller than the non-turbo cups and so measuring those is a definitive answer.  I'd have to pull out the caliper's to confirm, and I'm lazy too...
Andrew
Now that's interesting..
The head I bought from Tyler way back had some small cracks in the precups so I knocked them out and had some from an NA head fitted. My main reasoning behind it at the time was to lower the compression a tad due to the boost I was planning on running.
I have about 8 precups I think sitting around that must be out of a TD head as they are smaller.
Reply #5December 11, 2008, 06:51:06 pm
TD_Bunny
« Reply #5 on: December 11, 2008, 06:51:06 pm »
Quote from: "zukgod1"
Quote from: "arb"
OH SNAP!!!!   :lol:
I can never seem to find the right numbers on the block to identify which type it is. I have four blocks to look at and I think i just realized i keep looking at the head numbers but never looked at the block numbers before. where is the stamp on the block?
Reply #6December 11, 2008, 10:02:46 pm
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: December 11, 2008, 10:02:46 pm »
Look at the block as if its in the engine bay horizontally.
Infront of cylinder number 3, third in towards the tranny from the left, there is a flat spot. Often VERY hard to read. It should say two letters followed by numbers. Mine Reads MF #####(i can't make out the numbers anymore)
Hope that helps. try solvent and a tooth brush.
Reply #7December 11, 2008, 10:58:43 pm
  • 2932
« Reply #7 on: December 11, 2008, 10:58:43 pm »
Every "N" head (last letter in part # is an N) I've seen are TD heads.
 Look for a dot on the prechamber,... that's a TD.
