Author Topic: 1.9TD Crank same as 1.9TDI crank?  (Read 3277 times)
December 09, 2008, 08:30:46 pm
zagarus
  • 619
« on: December 09, 2008, 08:30:46 pm »
Just curious if a 1.9TD (aaz) crank is the same as a TDI crank.
Just looking for options to this crank pulley upgrade for the fabled wobbly pulleys on the TD.
Reply #1December 09, 2008, 09:22:16 pm
blackdogvan
  • 574
« Reply #1 on: December 09, 2008, 09:22:16 pm »
yes, its the same. When my pulley started its death wobble its the route I went. I believe its NW fuel injection down the road in van that can machine your crank in place to accept a tdi pulley or pop it out & have it machined to fit. There have been a few alternative methods successfully tried too.
1991 Vanagon 1.9 mTDI
Reply #2December 09, 2008, 09:24:36 pm
zagarus
  • 619
« Reply #2 on: December 09, 2008, 09:24:36 pm »
which method would you think is the better one?  im sure machining the stock 1.9td crank would be the most cost effective one but at the same time this is a rebuild engine so a new crank wouldn't hurt either.
Reply #3December 09, 2008, 10:00:32 pm
blackdogvan
  • 574
« Reply #3 on: December 09, 2008, 10:00:32 pm »
I know there are others here who have tried all the options so stand by...
Reply #4December 09, 2008, 10:19:53 pm
g-spec
  • 289
« Reply #4 on: December 09, 2008, 10:19:53 pm »
I have done a re-machined crank to accept the TDI pulley.....done by fastTD! no problems or complaints there....excellent work - this was done on my sisters car while I was rebuilding the motor after a TB broke.
My golf im running a new bolt and gear with 2 dowel pins. I didnt want to pull/rebuild the motor, so thats why I chose this method. I plan on using the same one on the motor I will be building for my corrado.
Reply #5December 10, 2008, 10:21:07 am
rallydiesel
  • 1880
« Reply #5 on: December 10, 2008, 10:21:07 am »
The only TDI cranks you can use as direct replacements are the 1Z and AHU. The others have an oil pump gear on them.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6December 10, 2008, 10:57:20 am
zagarus
  • 619
« Reply #6 on: December 10, 2008, 10:57:20 am »
awesome thanks for the info!
Reply #7December 10, 2008, 11:32:52 am
blackdogvan
  • 574
« Reply #7 on: December 10, 2008, 11:32:52 am »
Aww crap, sorry I should have mentioned that...
Reply #8December 10, 2008, 12:23:40 pm
zagarus
  • 619
« Reply #8 on: December 10, 2008, 12:23:40 pm »
no worries. You have been more then helpful.   I love this site, it is the only one where everyone is mature and very very very helpful.
Thanks once again everyone.  Now to figure out my next step hehe.
