Author Topic: Engine block expansion plug Q.  (Read 2213 times)
December 08, 2008, 10:04:08 pm
Dakotakid
  • 1240
« on: December 08, 2008, 10:04:08 pm »
There is an expansion/soft plug which fits into the transmission end of the 1.6 block. Removal of it allows access to the gear end of the intermediate shaft. Question: is this plug identical (36.6 mm) to the three coolant plugs on the firewall side of the block?
Do you guys use blue locktite when you insert these?
Reply #1December 08, 2008, 10:14:33 pm
Green79
  • 27
« Reply #1 on: December 08, 2008, 10:14:33 pm »
On my 1.5 it is exactly the same (36.6mm) as the other three. I would guess the 1.6 is the same... but that's just a guess.
I used a thin layer of blue RTV sealant on the plugs. If they fit correctly and the mating surfaces of the holes are clean, you shouldn't need any sealant. But, it never hurts to have an extra bit of insurance against leaks.
'79 1.5 Rabbit
Reply #2December 08, 2008, 10:20:50 pm
Dakotakid
  • 1240
« Reply #2 on: December 08, 2008, 10:20:50 pm »
I did some digging on internet: aviation grade permatex. Hope I can get it in a small amount.
Thanks 79
Reply #3December 09, 2008, 07:07:44 am
« Reply #3 on: December 09, 2008, 07:07:44 am »
Quote from: "Dakotakid"
Thanks 79
You can and it's not very expensive. I bought a small container at the local Napa.
Reply #4December 09, 2008, 09:09:16 am
arb
« Reply #4 on: December 09, 2008, 09:09:16 am »
Quote from: "zukgod1"
Thanks 79
Ditto. Its what I use.
