Author Topic: Green Plug on Transmission  (Read 4502 times)
December 07, 2008, 12:43:50 pm
Terrin
  • 11
« on: December 07, 2008, 12:43:50 pm »
Hello All:
Does anybody know how to get that Green Plug off on the Transmission so that I can align the timing? Is there a a special tool? Any help is appreciated. Thank you.
Reply #1December 07, 2008, 01:30:19 pm
handedyourhat
  • 33
green plug
« Reply #1 on: December 07, 2008, 01:30:19 pm »
There is a special tool from VW, but you dont need to buy an expensive tool like that, just find a nut the same size that fits and weld it to a
bolt and unscrew away 8)
Dan
Most of the time I get sooo far ahead of myself that I have to stop and let myself catch up......
87 jetta 1.6L TD project
87 jetta 1.6L TD Daily  (new 1.6, Giles,3", inner cooled. Home made fuel...
95 jetta 1.9L TD project
94 golf TD new edition to my family (LOL)
Reply #2December 07, 2008, 03:00:29 pm
  • 2932
« Reply #2 on: December 07, 2008, 03:00:29 pm »
Yeah, I welded the bottom half of an injector to a socket,.. there was still a plastic plug that it wouldn't remove.
 1 1/16"
Reply #3December 07, 2008, 03:14:46 pm
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: December 07, 2008, 03:14:46 pm »
i used a monkey wrench the first time. it's always just been hand tight since.
Vice grips even..?
Reply #4December 07, 2008, 03:40:26 pm
  • 2932
« Reply #4 on: December 07, 2008, 03:40:26 pm »
Yeah, I was using channel locks.
Reply #5December 09, 2008, 04:13:12 pm
rubadubdub
  • 109
« Reply #5 on: December 09, 2008, 04:13:12 pm »
if you know someone with a late 90s fiat punto the wrench to get the wheel nuts off with fits inside perfectly
1991 Mk2 Golf GTD
Reply #6December 21, 2008, 12:48:03 pm
Terrin
  • 11
« Reply #6 on: December 21, 2008, 12:48:03 pm »
Thanks for the replies. Eventually I went to ACE Hardware and bought a nut that fit the plug. The Nut was big enough to still stick out. I put a socket over that and took it out.
