Author Topic: HELP!!  (Read 6033 times)
December 06, 2008, 09:08:18 am
96jetta
HELP!!
« on: December 06, 2008, 09:08:18 am »
i changed the head guasket and the timing belt plus the tentioner, every thing is on perfect mark but it still doesnt run like it did at all (if it runs at all). as muchas i play with timing and pull every thing apart it still doesnt like life is there any one in the cambridge kitchener/waterloo area that could give me a hand?
thanks Geoff
Reply #1December 06, 2008, 09:37:06 am
TurboJ
  • 661
HELP!!
« Reply #1 on: December 06, 2008, 09:37:06 am »
How about injection pump timing?
Jetta II 1.6 TD 'Project 200'
Reply #2December 06, 2008, 10:59:41 am
HELP!!
« Reply #2 on: December 06, 2008, 10:59:41 am »
you could always time it by ear... i think its even possible to loosen the injection pump bolts and time it while the engine is running... either that or you need to loosen bolts, move pump, tighten and start and repeat as necessary.
you can get the car running pretty good that way... enough to drive it to someone who knows how to do it right.  just keep an eye on smoke...
Reply #3December 06, 2008, 11:08:08 am
vwt4
  • 107
Re: HELP!!
« Reply #3 on: December 06, 2008, 11:08:08 am »
Quote from: "96jetta"
thanks Geoff
Did you remove the head bolts in the correct sequence?..if not your head may be warped :/
Did you check the head wasnt warped?
Did you use new bolts and tighten them correctly?
As someone else said, IP timing. Is it set correctly?
Reply #4December 06, 2008, 11:26:15 am
96jetta
HELP!!
« Reply #4 on: December 06, 2008, 11:26:15 am »
ya the head was torqued down in the pattern given in the book. but the original bolts were used and the head was never checked for warpage. i also played with the injection pump to get the timing right but it just pours out white or gray smoke
Reply #5December 06, 2008, 11:34:20 am
g-spec
  • 289
HELP!!
« Reply #5 on: December 06, 2008, 11:34:20 am »
The bolts are one time use...they stretch. I would replace them.
As for the head I would get it checked if its warped and I would get it planed at a machine shop. As for the not running right....you need a special guage to set the timing on the injection pump.
Check to see if you have pressure building up in the coolant system.
Reply #6December 06, 2008, 11:36:23 am
Jet A
  • 125
HELP!!
« Reply #6 on: December 06, 2008, 11:36:23 am »
White or gray smoke is an indication of un burnt diesel. injected to late in the combustion cycle. That to me indicates you have the timing inccorrect, and could posibly have either the timing belt off a tooth, or the injectors are out of tune.
When i was diagnosing my rough start problem after a pump install, i pulle dof the exhaust mani, and watched each cylinder, found out one cylinder had a bad injector and was blowing white smoke.
I would say make sure you get that baby set up as close as possible, and then timing it by ear.
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #7December 06, 2008, 12:02:32 pm
HELP!!
« Reply #7 on: December 06, 2008, 12:02:32 pm »
Perhaps try setting the timing from scratch:
http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28
Pump timing is important, but so is the cam timing.
Reply #8December 06, 2008, 12:03:40 pm
96jetta
HELP!!
« Reply #8 on: December 06, 2008, 12:03:40 pm »
is there a way to teat the injectors? or injection pump? to make sure the timing on them is ok?
Reply #9December 06, 2008, 12:10:43 pm
HELP!!
« Reply #9 on: December 06, 2008, 12:10:43 pm »
Follow the timing procedure and it will be correct. :wink:
 If you didn't have injector issues before you swapped headgaskets it's unlikely that that is the issue now.
Reply #10December 06, 2008, 12:27:22 pm
96jetta
HELP!!
« Reply #10 on: December 06, 2008, 12:27:22 pm »
is it at all likely that the compression is low and i need to do the rings?  :cry:
Reply #11December 06, 2008, 12:37:20 pm
HELP!!
« Reply #11 on: December 06, 2008, 12:37:20 pm »
Let's start with:  why did you replace the headgasket in the first place, and how was the engine running *before* you did the work ?
Reply #12December 06, 2008, 01:17:03 pm
96jetta
HELP!!
« Reply #12 on: December 06, 2008, 01:17:03 pm »
it was running fine but i dstroyed 2 of 8 lifters in the head so i pulled the head to make sure i didnt bend the valves of smash the pistons. which i didnt. and i put all new lifters in the head. i did put a 3 hole guasket on instead of the origional 2 hole. and it hasnt been right since. its been timed and timed over and over again
Reply #13December 06, 2008, 01:55:21 pm
mattbondy
  • 38
HELP!!
« Reply #13 on: December 06, 2008, 01:55:21 pm »
How did you destroy the two lifters? Significant change in valve timing resulting in valve-piston contact? If that is the case it might be possible that the valves are not okay.
Reply #14December 06, 2008, 04:55:41 pm
  • 3468
    • McScrubbins Body Wash
HELP!!
« Reply #14 on: December 06, 2008, 04:55:41 pm »
Quote from: "jtanguay"
I have done the method of loosening the pump and doing that.
It worked although it is credited as being "hill billy timing"  :P
