Author Topic: Anyone have experience with Water/Meth injection?  (Read 2674 times)
December 01, 2008, 05:38:36 pm
Jettagli16v
  • 344
« on: December 01, 2008, 05:38:36 pm »
I know on gas motors a cheap ($300) Water/Methanol (50/50 mix) will give you an intake air temp in the 30-40 F  range.
I also know that water meth kits for big diesel trucks are one of the hot newer things to add to the mix.
Anyone personally run one of these?
Curious to know the results on an ol' IDI.
My plan is to install this instead of an intercooler.
Maintain the short length of intake air travel,
keep temps WAY lower than even the biggest FMIC, when the boost is on.
The only negative is that you have one more tank of fuel to maintain.
(but you only need that for high boost runs... if you set it to turn on at 11 PSI, you can do everything the same except for the fun stuff)
Thanks in advance,
BRAD
Reply #1December 01, 2008, 06:30:09 pm
« Reply #1 on: December 01, 2008, 06:30:09 pm »
I injest a lot of water everyday, but try to stay away from meth anymore :lol:
Seriously though, I haven't ran any in my IDI. I have a friend that did something like this to his cummins and really liked the results. To each his own, I would like to know if you try and your results.
Reply #2December 01, 2008, 07:54:22 pm
truckinwagen
  • 1895
« Reply #2 on: December 01, 2008, 07:54:22 pm »
I am doing this with a kit I got on ebay for $200, like you said it should tame intake temps and allow for really short intake lengths, supposedly it also adds power as the water droplets turning into steam on the power stroke generates additional cylinder pressure, it also effectively lowers EGT's
should be fun
83 Opel Kadett Diesel
Reply #3December 01, 2008, 11:23:24 pm
Jet A
  • 125
« Reply #3 on: December 01, 2008, 11:23:24 pm »
Im running water meth. My nozzle is a bit small at the moment but it does help the egts a bit. Pulling water meth out of the washer reserve tank. using a 3gph nozzle with a 150psi pump injecting the water pre turbo.
Built the system for around $100
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #4December 02, 2008, 03:37:17 am
Turbinepowered
  • 1206
« Reply #4 on: December 02, 2008, 03:37:17 am »
Quote from: "truckinwagen"
In a diesel that water is going to have reached boil-off temperature before the power stroke. Hot chamber, high compression temps, low boiling point for the water. You're seeing steam on the compression stroke.
Reply #5December 02, 2008, 04:37:55 am
AudiVWguy
« Reply #5 on: December 02, 2008, 04:37:55 am »
Here is my project, helps egt's about 100 degrees. Need to try a bigger nozzle.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=17196
Reply #6December 02, 2008, 05:14:55 am
« Reply #6 on: December 02, 2008, 05:14:55 am »
i've tried it on my car... it does seem to reduce the smoke, but makes a pinging sound in the engine.. needless to say i don't run it anymore!  but maybe my spray nozzle is too close to the intake ports??? not enough time to atomize properly?
Reply #7December 02, 2008, 09:19:35 am
Turbinepowered
  • 1206
« Reply #7 on: December 02, 2008, 09:19:35 am »
Quote from: "jtanguay"
Perhaps more water, less methanol? If you're "pinging" you're probably pre-igniting the methanol in the mix, adding a little more water might help control that?
