Author Topic: Warming up diesel before it gets into the motor?  (Read 5514 times)
November 29, 2008, 04:42:14 pm
lildevil
  • 49
« on: November 29, 2008, 04:42:14 pm »
I'm sure people have done this, ive seen it on the Vortex but the search is down, is there anyway to heat the diesel before it goes into the motor? its starting to get chilly here, i have no problem starting, but when it was -20 it was runnin a little rough for a couple seconds, which would be one of my GP's burnt out, but does anyone have heated lines in there diesel?
Delmonte...Some Serious *** My Friend
Reply #1November 29, 2008, 05:41:39 pm
Caddyman
  • 7
Re: Warming up diesel before it gets into the motor?
« Reply #1 on: November 29, 2008, 05:41:39 pm »
Quote from: "lildevil"
I've always wanted to try this; http://www.arctic-fox.com/sitepages/pid20.php
Reply #2November 30, 2008, 10:33:34 am
« Reply #2 on: November 30, 2008, 10:33:34 am »
that does sound pretty cool there caddy. Just out of curiosity why are you willing to spend all this money on heated fuel lines when you car starts and runs perfectly fine in -20 weather?
any car will run rather shotty for a few seconds in the cold :P
But cool idea none the less  :D
Reply #3November 30, 2008, 10:50:22 am
lildevil
  • 49
« Reply #3 on: November 30, 2008, 10:50:22 am »
lol it gets -50 here at times, its just easyer on the motor, i hate when it runs rough, i seen that fox site but cant figure anything out, i know theres cheaper ones out there
Reply #4November 30, 2008, 11:58:17 am
« Reply #4 on: November 30, 2008, 11:58:17 am »
very true.. I did happen to see something somewhere... Had some sort of like.. electrical cord im guessing wrapped around the fuel lines.. i dunno if it would be a cheaper option.. but surely much more simple then replacing all the fuel lines.. i dunno where i read it or saw it.. but it seemed cool.. OH I remember! i read it on some WVO conversion thread.. he used it to keep his veggie oil warmed up for the trip from the tank to the engine..
so im sure the concept would work to keep diesel warmer..
Reply #5November 30, 2008, 12:00:50 pm
  • 1739
« Reply #5 on: November 30, 2008, 12:00:50 pm »
Go to http://www.plantdrive.ca/ and get a Vegetherm .  Just wire it so you can preheat the fuel for a few seconds and shut it down after a minute or two. And yes it will get hot fast enough to work. Within 20 secondes it'll be too hat to touch with your hand. And all for about $100.
Reply #6November 30, 2008, 12:09:33 pm
dieselweasel
  • 312
« Reply #6 on: November 30, 2008, 12:09:33 pm »
Do you have a block heater?  Plug it in at colder temperatures and she will start and run great.
Reply #7November 30, 2008, 02:56:07 pm
Reply #8November 30, 2008, 10:34:49 pm
lildevil
  • 49
« Reply #8 on: November 30, 2008, 10:34:49 pm »
thanks guys i will forsure look into both of those, might be a good way to go!!
Reply #9December 01, 2008, 08:10:49 am
« Reply #9 on: December 01, 2008, 08:10:49 am »
I used a fuel filter mount from a 01ish Dodge Cummins. It has a water sensor and drain, and a built in fuel heater as well.
Then theres the availability of a filter with a 2 micron rating as well with this set up.
I also like the fact if I'm out in the sticks I know I'll be able to find a filter for a Dodge LONG before I'll be able to find a filter for a VW.
Reply #10December 01, 2008, 02:12:42 pm
lildevil
  • 49
« Reply #10 on: December 01, 2008, 02:12:42 pm »
where can you get those, there prolly pretty pricey eh?
Reply #11December 01, 2008, 08:42:24 pm
« Reply #11 on: December 01, 2008, 08:42:24 pm »
Actually no it wasn't to bad.
It's been a while but I think it was under shipped. Like $70.00 actually.
Reply #12December 01, 2008, 09:57:37 pm
lildevil
  • 49
« Reply #12 on: December 01, 2008, 09:57:37 pm »
really, could you pm me or give me a heads up where you got it? thanks man
Reply #13December 02, 2008, 03:10:58 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #13 on: December 02, 2008, 03:10:58 am »
We use one version of these in some of our trucks: http://www.cumminsfiltration.com/en/products/en_prod_inn_fuelpro.shtml.
They have an optional heater inside.  Ours are 24 volt, they use 10 amps, and the heater is internally switched to come on at temperatures below 110 deg. F. and turn back off at temps above 150 deg. F.
One of the beauties of these is the clear filter housing lets you see exactly when the filter needs to be changed.  When new, the fuel level is very low in the housing, the top is empty.  As the filter starts to get restricted, the fuel level in the clear housing rises.  When you get near the top, you change the filter.  It has another plus in that if you don't have the proper filter or if the plastic bowl gets cracked, you can just spin on the regular metal Cummins fuel filter temporarily to keep you running.  I believe Ryder Fleet Products carries or can order these.
Calvin
91 VW Golf 1.6NA 5spd
Reply #14December 02, 2008, 05:20:35 am
« Reply #14 on: December 02, 2008, 05:20:35 am »
i would think that intake air heating is what you're really after.  even really cold fuel hitting the glow plug will ignite with the proper compression.  the intake air heater will help that process a whole lot!
but if you must heat the fuel, you might as well have it circulate while being heated to be beneficial on startup.  use a solid state fuel pump to draw fuel from a T in the fuel return, and then the outlet to the inlet of the pump.  i'm pretty sure the fuel stop solenoid must be activated though or it might not flow...
