Author Topic: When to change coolant  (Read 5005 times)
November 28, 2008, 02:34:03 pm
Matteo
  • 47
« on: November 28, 2008, 02:34:03 pm »
I read here that oil and antifreeze is key to long engine life. Recently I spoke with a chemist for the auto industry that shed some light on this for me. He said the result of blow by converts the water portion of the anti-freeze mix combines with the blowby and forms a corrosive mix that eats away at internals and seals. I'm sure this is not new to most of you.
My question is:
How often do I change the antifreeze? Should I do it based on miles rather than time?
Aircooled rules!
Biodiesel makes us better humans.
Make your own fuel and stick it to the man!
I never thought it was possible to Love a car.
Help me I'm sick!
Reply #1November 28, 2008, 04:17:17 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #1 on: November 28, 2008, 04:17:17 pm »
How exactly is blowby supposed to come in contact with coolant?  I'm not quite following that one.  Unless your cooling system is defective it should be a sealed system.
Calvin
91 VW Golf 1.6NA 5spd
Reply #2November 28, 2008, 05:14:45 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: November 28, 2008, 05:14:45 pm »
I also fail to see (in my mind) where the coolant comes in contact with combustion?
I have to buy a new head because that was happening. If that's happening changing the coolant is the least of your troubles.
I'd say every 6 months if you have a perfect working engine? no real reason. Just seems like a resonable amount of time to spend 15$ for some new coolant.
If not, when ever you see discolouration. That could also mean to change the head gasket (or you have other problems to contend with?)
Ed
Reply #3November 28, 2008, 06:13:25 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #3 on: November 28, 2008, 06:13:25 pm »
To answer the original question, the traditional reply is 1-2 years.  The newer extended life coolants are supposed to go up to 5 years.
Calvin
Reply #4November 28, 2008, 06:25:30 pm
Smokey Eddy
  • 3468
« Reply #4 on: November 28, 2008, 06:25:30 pm »
Wow way longer than i thought! Good to know!  :D
Ed
Reply #5November 29, 2008, 02:35:22 pm
GV2001
  • 3
« Reply #5 on: November 29, 2008, 02:35:22 pm »
Using VW G-12 antifreeze you can run it a long time. My 2001 Golf with 198K miles still has the original antifreeze. The only "new" G-12 was after the timing belt changes. The last TB change was done 2 months ago and when I removed the water pump there was no rust and the antifreeze looked just like the stuff I added from a new jug.
The only cardinal rule is to never mix any other antifreeze with the VW stuff. If you do it will turn to a substance that looks like mud.
Reply #6November 29, 2008, 04:06:38 pm
  • 3255
    • My collection of HOWTOs
« Reply #6 on: November 29, 2008, 04:06:38 pm »
Yeah, VW rates G12 as "lifetime"... and it's designed to change colour if for any reason it loses its effectiveness or gets contaminated... with, say, Prestone  :wink:
Reply #7December 01, 2008, 12:41:45 pm
Matteo
  • 47
« Reply #7 on: December 01, 2008, 12:41:45 pm »
I believe what the chemist was refering to was blowby contaminating oil, and through the head seal eventually or potentially contaminating the antifreeze...
Aircooled rules!
Help me I'm sick!
