Author Topic: AAZ fuel pump problem :(  (Read 5317 times)
November 25, 2008, 10:06:51 am
LoneWolf
« on: November 25, 2008, 10:06:51 am »
theres fuel going INTO the pump, but nothing coming OUT, the cut-off solanoid is wired up and its still not working, can anyone shed any light on the possible problems for me ?
 Matt
Reply #1November 25, 2008, 03:54:38 pm
« Reply #1 on: November 25, 2008, 03:54:38 pm »
Either not fully primed or the solenoid is stuck/bad. Take the solenoid off and check the plunger, and make sure power will suck it in. You should hear a click when it's installed.
Reply #2November 25, 2008, 05:30:55 pm
« Reply #2 on: November 25, 2008, 05:30:55 pm »
The stop solenoid working or not will not make any difference on the return flow out of the pump. If fuel is going in, something has to be coming out.  It's probably full of air
Reply #3November 25, 2008, 05:36:42 pm
LoneWolf
« Reply #3 on: November 25, 2008, 05:36:42 pm »
if its got an airlock, how do i bleed it out? i primed it with a hand primer, so i know theres fuel pressure going into the pump :?
Reply #4November 25, 2008, 06:06:44 pm
« Reply #4 on: November 25, 2008, 06:06:44 pm »
It shouldn't lock. The injection system is suppose to be self priming.
Was it a vacuum pump or a pressure pump? You can crack open the injector lines or the return line to try and help it a long.
Why is the pump empty of fuel?
Reply #5November 26, 2008, 04:34:44 pm
LoneWolf
« Reply #5 on: November 26, 2008, 04:34:44 pm »
the pump was found in a mates garage, from one of his old race engines, so it was void of fuel, but the cars running now thanks to my dad and bro while i was at work, cut-off solanoid had seized up through not being used
Reply #6November 26, 2008, 04:46:04 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: November 26, 2008, 04:46:04 pm »
Yayyyyyyyy
Ed
Reply #7November 26, 2008, 04:56:02 pm
LoneWolf
« Reply #7 on: November 26, 2008, 04:56:02 pm »
Cheers for the pointers guys  :D
Reply #8November 26, 2008, 05:26:49 pm
« Reply #8 on: November 26, 2008, 05:26:49 pm »
Glad to hear you got it fixed
