Author Topic: How to get correct timing belt tension without the gauge??  (Read 21137 times)
November 25, 2008, 07:43:50 am
AudiVWguy
« on: November 25, 2008, 07:43:50 am »
This might be a question that has crossed a lot of peoples minds when they are doing the T-belt. Those of you who have the tool, is there a measurement in inches or mm that is the same as what the tension gauge says?
Thanks,
-JB
Reply #1November 25, 2008, 08:11:31 am
« Reply #1 on: November 25, 2008, 08:11:31 am »
Tension gauge?
Are you refering to the gauge that tells you the tension on the timing belt?
Reply #2November 25, 2008, 09:00:02 am
DCC
  • 184
« Reply #2 on: November 25, 2008, 09:00:02 am »
Quote from: "zukgod1"
Tension gauge?
I think so. :D
You should be able to twist the belt 90º just in the middle between the camshaft and the pump. No more, no less.
Reply #3November 25, 2008, 09:17:11 am
« Reply #3 on: November 25, 2008, 09:17:11 am »
I thought it was 45 deg?
Anyone have a Bentley handy?
Reply #4November 25, 2008, 09:20:14 am
« Reply #4 on: November 25, 2008, 09:20:14 am »
For MK2 diesels the Bentley strongly recommends the use of the proper tool, with a 45 degree twist being the (very) approximate work-around (90 degrees is the work-around given for gassers).
For MK3 diesels Bentley completely dropped any mention of the workaround and insists on the proper tool... for both diesels and gassers.
Reply #5November 25, 2008, 09:32:18 am
« Reply #5 on: November 25, 2008, 09:32:18 am »
Thanks Vince.
Reply #6November 25, 2008, 11:03:05 am
DCC
  • 184
« Reply #6 on: November 25, 2008, 11:03:05 am »
Quote from: "Vincent Waldon"
Thanks for the info!
Reply #7November 25, 2008, 11:28:41 am
VW_Commuter
  • 355
« Reply #7 on: November 25, 2008, 11:28:41 am »
So what's the proper tool?  I'm at work and don't have access to my Bentley.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #8November 25, 2008, 12:52:10 pm
« Reply #8 on: November 25, 2008, 12:52:10 pm »
Yeah for mk1 they don't say anything about 45 deg, just the tool. For mk2 the manual says tool or 45 deg.
Proper tool is VW210.
Reply #9November 25, 2008, 01:00:39 pm
« Reply #9 on: November 25, 2008, 01:00:39 pm »
Looks like this:
The guys that carry VW specialty tools (Samstag, ZDmac, Hazet, Heyco, etc) generally have it... and for you Americans evidently Harbour Freight has a version.
Reply #10November 25, 2008, 01:24:25 pm
VW_Commuter
  • 355
« Reply #10 on: November 25, 2008, 01:24:25 pm »
The one at Harbor Freight, which has the same pic as the one you posted Vince :P, says it's for belts up to 3/4" thick.  What's the thickness of our belts?
Greg
Reply #11November 25, 2008, 01:40:41 pm
« Reply #11 on: November 25, 2008, 01:40:41 pm »
I'll have to find my mk1 bentley. I thought it said 90 in it.
Reply #12November 25, 2008, 02:19:37 pm
VW_Commuter
  • 355
« Reply #12 on: November 25, 2008, 02:19:37 pm »
I'm home now and just checked my brand spankin' new Continental timing belt, wait for it, 1" exactly.
Greg
Reply #13November 25, 2008, 02:37:39 pm
VW_Commuter
  • 355
« Reply #13 on: November 25, 2008, 02:37:39 pm »
Sorry, the width of the belt.
Greg
Reply #14November 25, 2008, 02:39:20 pm
« Reply #14 on: November 25, 2008, 02:39:20 pm »
they probably refer to the tool because some people might just guess at the angle, and ruin a motor... less liability for them  :wink:
