Author Topic: diesel into a Vanagon adapter wanted  (Read 4002 times)
November 23, 2008, 08:00:23 am
TOW'D
  • 100
« on: November 23, 2008, 08:00:23 am »
Howdy Gang,
 I'd like to get the adapter and flywheel to convert our 1986 Syncro to diesel- I don't have the replacement VW diesel motor yet but I'm looking.
any parts out there?
thanks
hank
way too many projects not much time
Reply #1November 23, 2008, 04:11:20 pm
CdnVWJunkie
  • 309
« Reply #1 on: November 23, 2008, 04:11:20 pm »
Hello Tow'd,
libbybapa is right regarding the diesel vanagon BH will mount onto the syncro trans, no adapter required.
I have a complete TD engine removed from a factory equipped TD syncro.  I also have the diesel bell housing.  I'm in Canada too but a good haul away.  PM me if your interested.
Reply #2December 04, 2008, 05:29:15 pm
fairweather
  • 85
    • TDI Syncro
« Reply #2 on: December 04, 2008, 05:29:15 pm »
Ive got a Kennedy Engineering adapter plate available if you want to use your existing bellhousing. Also have the KEP flywheel and PP.
New from KEP is about 700$, make me an offer if interested.
If you use the Diesel vanagon bellhousing you need to either mold the fuel tank to clear the starter which will be at 12 oclock or get a diesel syncro tank for 450$.
Tom
[email protected]
83 Caddy with CY code 1.6TD out of a rabbit.
Reply #3December 05, 2008, 08:18:35 am
TOW'D
  • 100
« Reply #3 on: December 05, 2008, 08:18:35 am »
Thanks for the info guys
I didn't know about the fuel tank problem
I'm still interested and will let you know after the New Year
hank
