Author Topic: Clutches  (Read 4736 times)
November 20, 2008, 05:29:17 pm
AdAm84
Clutches
« on: November 20, 2008, 05:29:17 pm »
What clutches are everyone using? I want to push between 120hp and 150hp. Are the 8V gas clutches the same as the diesels? I want to do this right the first time and don't want to fry a clutch.
Reply #1November 21, 2008, 08:09:22 am
Clutches
« Reply #1 on: November 21, 2008, 08:09:22 am »
www.clutchnet.com
Call them after you are done playing on site and tell them what you want to do as for power levels.
They make a 210mm set up for the small spline (8v) transmissions.
Search for 53 willys build thread, he has pics of thier set up in his thread.
I would recomend exactly what he is using. I have the 8 puck disc and I can slip it from accell at freeway speeds. I dont think that would be a problem with thier 6 puck disc.
Reply #2November 21, 2008, 03:33:42 pm
monomer
  • 414
Clutches
« Reply #2 on: November 21, 2008, 03:33:42 pm »
I'm using SPEC on my build. 034 motorsports sells them.
Stage3 (complete overkill - the way I wanted) was just over $300. This is a 6-puck sprung carbon deal.
www.michiganvw.org
Reply #3November 23, 2008, 04:30:44 pm
AdAm84
Clutches
« Reply #3 on: November 23, 2008, 04:30:44 pm »
What about this kit?
http://store.blackforestindustries.com/enpe1.html
Seems like a good price since it include the new flywheel. Its a ceramic 6 puck design.
Any thoughts?
Reply #4November 23, 2008, 04:50:34 pm
Clutches
« Reply #4 on: November 23, 2008, 04:50:34 pm »
I thought gas and diesel flywheels had different timing marks?
Reply #5November 23, 2008, 06:54:07 pm
blkboostedtruck
  • 1535
Clutches
« Reply #5 on: November 23, 2008, 06:54:07 pm »
Quote from: "zukgod1"
www.clutchnet.com
hey Dan i wonder if that place can change out a center spline and install one for an 8v instead of the 16v one i have?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #6November 24, 2008, 08:36:54 am
Clutches
« Reply #6 on: November 24, 2008, 08:36:54 am »
I doubt it Duane, would prob be cheeper to just buy a new one.
I'll bet you could sell the 16v on the whoretex though.
Reply #7March 12, 2009, 09:27:09 am
Clutches
« Reply #7 on: March 12, 2009, 09:27:09 am »
Quote from: "burn_your_money"
do gas and diesels have different timing marks? if so, i just figured out why my car wont ever time right. ive got a wheel off of a 92 gas jetta on my diesel. when i swapped my trans i decided to take the 210mm clutch and stuff too.
Reply #8March 12, 2009, 10:37:35 am
madrogers
  • 165
Clutches
« Reply #8 on: March 12, 2009, 10:37:35 am »
the gas flywheel i used has different marks on it , I had to use the dial guage to check the pump timeing at tdc diesel flywheel and then install the gas one check the dial guage setting and mark the gas flywheel with a new tdc mark. Make sence??
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #9March 12, 2009, 10:50:00 am
Clutches
« Reply #9 on: March 12, 2009, 10:50:00 am »
yes, it makes complete sense. but i dont have a dial inticator. damn i wish i would have known this a couple days ago when i had my tranny out. eh, hell with it, its almost time for a new clutch anyway.
