Author Topic: bumpers  (Read 4591 times)
November 20, 2008, 03:04:51 pm
danwithagolf
  • 43
bumpers
« on: November 20, 2008, 03:04:51 pm »
i have a 87 golf and i want to put the 91 92 bumpers on will they just bolt right up i think they would just want to make sure i have the smaller bumpers now kina beat up want they nicer ones thanks dan
87 Golf n/a
Reply #1November 20, 2008, 08:55:56 pm
  • 3468
    • McScrubbins Body Wash
bumpers
« Reply #1 on: November 20, 2008, 08:55:56 pm »
the gti bumpers fit on my '90 with some cutting done to the rear bumper and the metal bumper that's on the car.
The front ones need the square mounts.
Reply #2November 21, 2008, 10:48:25 am
Op-Ivy
  • 513
bumpers
« Reply #2 on: November 21, 2008, 10:48:25 am »
If you mean put big bumpers on a car with small bumpers then yes it is possible. But the mounting brackets are different between the two. You can't just swap the shell.
Reply #3November 21, 2008, 11:02:51 am
bumpers
« Reply #3 on: November 21, 2008, 11:02:51 am »
Well ya can but you need to cut the hooks off the small bumper rebar to get the big bumper plastic to fit, then swap the plastic mounts on the fenders as mentioned above.
Also you don't need the metal piece under the front bumper on the big bumper, I even will go as far to say I think when it's there and you convert to big bumpers that it restricts the air flow to the radiator.
I did the small to big conversion and left in there. I'll be removing it next time I have the bumper off.
There is also a plastic piece that goes from the rad support to the bumper on real big bumper cars to direct air flow to the rad. I don't have that either yet.
Reply #4November 21, 2008, 01:52:06 pm
  • 3468
bumpers
« Reply #4 on: November 21, 2008, 01:52:06 pm »
I added cardboard ... wings? i dunno i cut a card board box apart and put them all around the rad and i got much better cooling.
Reply #5November 21, 2008, 02:07:28 pm
bumpers
« Reply #5 on: November 21, 2008, 02:07:28 pm »
That would work for a while at least I'm sure.
I'm going to be hitting the salvage yards to get the correct PCS.
Reply #6November 21, 2008, 02:50:00 pm
danwithagolf
  • 43
bumpers
« Reply #6 on: November 21, 2008, 02:50:00 pm »
hmmm how dose the bumpers stop air flow to the rad? sounds like a bit of work all prob do it some day lol to much other things to be fixed first (struts) lol
87 Golf n/a
Reply #7November 22, 2008, 05:31:18 am
Ziptar
  • 565
bumpers
« Reply #7 on: November 22, 2008, 05:31:18 am »
I thought about putting the bumpers from the 91 I bought for the TD motor swap onto the 89. I pulled everything off decided the bumpers were too rough to do it. Since then original bumpers have grown on me, so I am glad I didn't
The side moldings and wheel arches are different between small and big bumper cars. Big bumper cars also have the skirt/cover on the rocker.
It'll still work but it'll look a bit odd where they come together.
vortex threads with some details..
http://forums.vwvortex.com/zerothread?id=2097162
http://forums.vwvortex.com/zerothread?id=642515
Reply #8April 19, 2009, 06:10:05 pm
Grey_Smoke
  • 83
    fling wing for the win.
bumpers
« Reply #8 on: April 19, 2009, 06:10:05 pm »
I have an 86 and I am working on swapping the bumpers, I think that the easiest thing to do is to switch the mounting brackets, because all that you have to do is drill two holes right beside the original one's and then you can bolt it on. the brackets are identical across the mk2s and and the big bumpers bolt right on.   I will post pics when I am done, if you want.
« Last Edit: August 24, 2011, 11:12:17 am by Grey_Smoke »
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
