Author Topic: anyone know much about the crankcase vent. tube?  (Read 1961 times)
November 20, 2008, 07:23:11 am
James8485
  • 223
« on: November 20, 2008, 07:23:11 am »
local machanic said i had a small oil leak and i need to replace the crankcase vent tube?
to be aunest is that that black hard tube thats at the front of the motor that comes off that puck thing and goes down to the block?
is this if done but ones self easy to put on any headaches along the way?
---------James--------
Reply #1November 20, 2008, 07:33:00 am
« Reply #1 on: November 20, 2008, 07:33:00 am »
I'm guessing you have the 1.9 AAZ engine, if that's the case then yes it's the plastic tube that runs from the valve cover to the front of the block.
It shouldn't be that hard to replace if you know how to run a wrench.
Reply #2November 20, 2008, 08:45:23 am
molgrips
  • 134
« Reply #2 on: November 20, 2008, 08:45:23 am »
On mine, the hose just pulls out of the hockey puck, and at the other end there's just a small clip holding it in place, which you pull out.
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
Reply #3November 20, 2008, 11:01:07 am
stewardc
« Reply #3 on: November 20, 2008, 11:01:07 am »
It's normally not the pipe itself that's the problem, but the part that bolts to the block. Get both parts. It's an easy fix.
