need source for crank bolt
Topic: need source for crank bolt (Read 2010 times)
November 18, 2008, 05:12:38 am
derekp
November 18, 2008, 05:12:38 am »
Where can I buy a crank bolt for the timing belt sprocket?
PartsPlace tells me they dont have them and local VW claims they cant get them
Sources appreciated!
Thanks!
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
November 18, 2008, 05:19:40 am
VW_Commuter
November 18, 2008, 05:19:40 am »
I bought mine, all 3 of them, from my local VW dealer. It's the same bolt as the AAZ engine, listed in ETKA as :
"905 771 01" "12 point socket head screw" "M14X1,5X47"
Sounds like your local dealer parts jockeys are lazy and didn't bother to do any cross referencing to me.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
November 18, 2008, 05:28:13 am
derekp
November 18, 2008, 05:28:13 am »
lazy is an understatement.
They come out to the counter with a picture of the affected area.
If the part is not pictured or not exactly for that year make model they shrug and say "sorry".
Thanks for the info I'll try them again.
The fleet
94 suburban (mine)
November 18, 2008, 05:57:41 am
molgrips
November 18, 2008, 05:57:41 am »
I got mine from the dealer too, for a few quid.
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
November 18, 2008, 12:40:14 pm
Jet A
November 18, 2008, 12:40:14 pm »
Hardware store
forget what size mm but its metric fine. use a high grade bolt.
Dont care what anyone says, a good grade bolt beats a vw bolt anyday.
85 vw golf NA ----> 2b TD Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
