IP Ugliness
Topic: IP Ugliness (Read 2733 times)
November 17, 2008, 08:57:32 pm
VW_Commuter
IP Ugliness
November 17, 2008, 08:57:32 pm »
The previous owner of my Jetta didn't do a very good job of keeping the water out of the fuel system as evidenced by the following pics.
IP cam plate
IP Roller
Ugly with a CAPITAL U. I was really impressed with the depth of the pits on the cam plate and on the rollers. The areas that now look like the surface of the moon used to look nice and shiny. Good thing I have that cam plate and 10mm head that I got off of Jimfoo through ebay or things would be really ugly. Giles has a kit with the rollers, shafts, and the special curved washers that I'm going to get and that will replace everything else. The head that came off the pump doesn't look too bad but I won't be able to judge it completely until I finish with all of the rest of the IP internals and housing in the parts washer.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
November 17, 2008, 09:04:53 pm
blkboostedtruck
IP Ugliness
November 17, 2008, 09:04:53 pm »
candidates for the wall of carnage ?
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
November 17, 2008, 09:09:46 pm
VW_Commuter
IP Ugliness
November 17, 2008, 09:09:46 pm »
I was thinking of hanging it on a chain around my neck for some great Diesel Bling :lol:
Greg
November 17, 2008, 09:57:51 pm
IP Ugliness
November 17, 2008, 09:57:51 pm »
If i knew what i was doing that TR3 or what ever it says would say GTD :wink:
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
November 17, 2008, 10:00:18 pm
Quantum TD
IP Ugliness
November 17, 2008, 10:00:18 pm »
I've got a couple of pumps that are similar, but not quite that bad. Most sat outside exposed for some time, and still aren't that rough.
Yeetch!
November 18, 2008, 07:42:47 am
IP Ugliness
November 18, 2008, 07:42:47 am »
That's nasty, just nasty.
November 18, 2008, 11:25:16 am
Gearhead
IP Ugliness
November 18, 2008, 11:25:16 am »
I had a pump like that. The reason mine was like that was the "engine stopped running" so they parked it. I thought it stopped running because it ingested some water, and that water sat at the bottom of the pump while it sat for a long time. The lower section of the camplate and rollers were messed up. The top part was nice & shiney.
'82 2 Door 1.6N/A
Rabbit '85 Cabrio project
IP Ugliness
