Author Topic: Feeler :may have a 97 AAZ T-bone for parts  (Read 8530 times)
Reply #15November 21, 2008, 11:14:23 am
  • 1739
« Reply #15 on: November 21, 2008, 11:14:23 am »
Quote from: "jtanguay"
i've been looking for a transmission... you don't happen to have the code do you? how much would you want for it???  it would be to swap into a mk2, but i have a cable shifter... just need the hydraulic clutch bits as well.  (although i've heard of some interesting ways of just hooking up the master cyl with the original mk2 pedal...)
thanks
Hey Mr tanquay
I don't know the code . I',m pretty sure it has the oem trans in it though. I don't think it was ever changed for another. And i don't remember which shift linkage it has. What would you offer with/without delivery ? [ i could use and excuse to drive to T.O.]
Reply #16November 22, 2008, 07:55:34 am
dieselherb1
  • 354
AAZ parts
« Reply #16 on: November 22, 2008, 07:55:34 am »
I have a shopping list! Could use a turbo intake and exhaust manifold, IP.
Herb 22427
Reply #17November 22, 2008, 10:13:02 am
  • 1739
Re: AAZ parts
« Reply #17 on: November 22, 2008, 10:13:02 am »
Quote from: "dieselherb1"
Herb 22427
You're on the list.
Reply #18November 24, 2008, 07:13:42 am
Turbinepowered
  • 1206
« Reply #18 on: November 24, 2008, 07:13:42 am »
Quote from: "the caveman"
I have one that all the valve are bent. The rest of the head is okay. I cpuld strip it down and i'll sell it for $75 plus the shipping would be alot less also, possibly as little as 50 quattloos
Hmmm, sounds much more my aims. How badly out of plane is it, if at all?
Reply #19November 24, 2008, 07:46:08 am
  • 1739
« Reply #19 on: November 24, 2008, 07:46:08 am »
I do know that before the crank pulley kicked the bucket the compression was good. i had checked it a few months before and they were all close to 400 if not above and no oil in the overflow so no problems with headgasket/head warp. I will check with a straight edge if you want it.
Reply #20November 26, 2008, 03:57:46 am
Turbinepowered
  • 1206
« Reply #20 on: November 26, 2008, 03:57:46 am »
If it won't be too much trouble, yes please. I'm an information junkie, so you'll be feeding my habit. :D
Reply #21November 27, 2008, 07:42:48 am
starrd
  • 128
« Reply #21 on: November 27, 2008, 07:42:48 am »
Is the turbo a K14?  If so how much?
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #22November 27, 2008, 09:53:32 am
  • 1739
« Reply #22 on: November 27, 2008, 09:53:32 am »
Quote from: "starrd"
I'm not sure which one it has, the car isn't in front of me . I will knwo more in the next few days whether i will e getting it and if so i'll let you know. If it seems like it's in very good shape i would want $150.
Reply #23December 06, 2008, 09:28:38 am
  • 1739
« Reply #23 on: December 06, 2008, 09:28:38 am »
Well sorry everyone, but i never heard back from the guy. He may resurface ,but unless it's in the next 3 weeks i won't be able to do anything until spring.
