Author Topic: ~Mechanical 1.6td Custom built MLS head gaskets!!!~  (Read 20756 times)
Reply #15November 17, 2008, 01:55:46 pm
monomer
  • 414
« Reply #15 on: November 17, 2008, 01:55:46 pm »
I'll take 2...
-1983 Rabbit LX 1.6/1.9 VNT build
Michigan Volkswagen Enthusiasts
www.michiganvw.org
Reply #16November 17, 2008, 06:47:33 pm
« Reply #16 on: November 17, 2008, 06:47:33 pm »
I would be interested in one for my 85. I haven't got it back form the machinist yet to measure piston protrusion. Depends on the price though...I would rather have 2 gaskets for that price. How low will he go?
Reply #17November 17, 2008, 07:32:00 pm
53 willys
« Reply #17 on: November 17, 2008, 07:32:00 pm »
Quote from: "theman53"
I dont know how low he will go?? he had just mentioned the quantity price break briefly and honestly I cant really wait for a group buy situation anyway..I'm gonna order two gaskets from him...if they look good when I get them, THEN we could/should try a GB or something to help bring the price down??
after blowing my fiber HG on on the test drive of my build...I would pay $200 a piece for a GOOD MLS gasket....stock gaskets suck!!! and I know I wont be able to stay away from at least 20psi..so I need something to make this head stay in place.
I will keep you guys updated!! 8)
Reply #18November 17, 2008, 07:51:09 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #18 on: November 17, 2008, 07:51:09 pm »
sorry, MLS? What does this abbreviation mean?
Reply #19November 17, 2008, 08:29:19 pm
Possum79
  • 276
    • http://www.poscarclub.com
« Reply #19 on: November 17, 2008, 08:29:19 pm »
MLS is Multi-Layer Steel.
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
Reply #20November 17, 2008, 08:29:22 pm
53 willys
« Reply #20 on: November 17, 2008, 08:29:22 pm »
Quote from: "vanagonturbo"
Multi-Layer Steel
Reply #21November 17, 2008, 09:24:33 pm
foxracer1
  • Authorized Vendor
  • 991
« Reply #21 on: November 17, 2008, 09:24:33 pm »
I plan to run a 1.9 MLS but currently i have a factory fiber gasket. Gonna use ARP and MLS just for security, but i don't think the factory fibers are that bad.
In an effort to get my car that has been sitting for 10 plus years we pulled the head to replace the head gasket. We sanded the head and block with some fine sandpaper and one of the steel blocks found on the front subframe. Only had a 2 notch even though the engine had a 1 notch on it. Slapped it together and have been pushing 20 psi since. Also with just new stretch bolts.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #22November 17, 2008, 10:05:38 pm
53 willys
« Reply #22 on: November 17, 2008, 10:05:38 pm »
Quote from: "foxracer1"
man I don't know what's with with my fiber gasket...it sucked big time on my car.
arp studs+fiber HG+20psi=blown in 2 spots
maybe I have high drive pressure with my hybrid turbo????
I would never trust running 20psi daily on a fiber HG...I thought I could after reading the forums..but if it was me I would not waste my time with fiber..even more if your running big boost....
Reply #23November 17, 2008, 11:12:49 pm
Turbinepowered
  • 1206
« Reply #23 on: November 17, 2008, 11:12:49 pm »
Quote from: "53 willys"
Not to doubt your checks, but how assiduously did you check your head for straightness? I imagine that a perfectly flat head wouldn't blow out a fiber headgasket even at 25+ PSI, but one that's a touch out of plane would probably let go much earlier.
Balance of forces and all that.
Reply #24November 18, 2008, 12:07:01 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #24 on: November 18, 2008, 12:07:01 am »
Multi-Layer Steel
Ok gotcha.
Been running an AAZ Hg on my Mech engine for 17k now with no prblems. 25psi daily and I am not nice to it.
Reply #25November 18, 2008, 07:41:54 am
« Reply #25 on: November 18, 2008, 07:41:54 am »
Quote from: "Turbinepowered"
The head was COMPLETELY gone through at the machine shop and was planed flat.
It was a strange situation for sure, he didn't even use a cheap gasket it was a German gasket from Myke if I remember correctly but sure a sh*t it was blown.
He did mention the studs "felt" different when he went for a retorque.
Once he gets a MLS in there and buttons it up I don't see him having another problem.
Reply #26November 18, 2008, 07:47:59 am
53 willys
« Reply #26 on: November 18, 2008, 07:47:59 am »
both my block and head got decked....
if I was to blame it on something I would say it should have been retqed...before I drove it...I think if I would have it may have lasted longer.
factory service manuals says that on a fiber gasket you need to torque the head down..start it and let it run to operating temp(with NO coolant Pressure)..shut it off let it cool...then retorque....I did not reTQ..and when I did finally reTQ the studs were not evenly clamped...some took more turns then the others..
I need to get a drive pressure gauge!! just to make sure I'm not way out of spec on my DP....
Reply #27December 06, 2008, 08:18:17 am
53 willys
« Reply #27 on: December 06, 2008, 08:18:17 am »
ok guys if you want a custom MLS gasket for your 1.6 then yes it can happen!
my gaskets showed up to Thailand yesterday! and John at gaskets to go sent me a quote on the 3 different thicknesses...
he said he can not guarantee the sizes....SO the VW spec of 1.57mm(2notch) would be a 1.50mm from gaskets to go and the VW spec of 1.61(3notch) would be 1.60mm
anybody see any problems with the sizing??
prices....
1.4mm-1.5mm=$139.95......if we buy more then 5 it's $129.95
1.6mm=$149.95......if we buy more then 5 it's $139.95
$12.95 for shipping.....and $6.00 for each extra gasket you have shipped...
if anybody wants one/some let me know we will try to work something out....
Reply #28December 06, 2008, 10:12:40 am
53 willys
« Reply #28 on: December 06, 2008, 10:12:40 am »
ok guys the more I think about it the more I don't want to mess with any money exchanging or reshipping just to save $10....its not really worth it to me...and as you guys know my car is in pieces in my shop and I wanna get it running sooner then later....So if you want a gasket call john using "skype" link on gasketstogo.com he is VERY easy to deal with.
and if you wanna wait for me to get mine then that's fine...I will be posting pics/opinions of the gasket soon as I get it...
i'm gonna get a 2 notch and a 3 notch.....
Reply #29December 23, 2008, 05:19:51 am
Alleslowbuged
  • 270
« Reply #29 on: December 23, 2008, 05:19:51 am »
Dear 53 Willys,
something new here, did you get your headgasket?
I am still waiting for news, because i also wand to buy one.
Best Regards
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
