General Information
Troubleshooting
can anyone ID these nozzles?
Topic: can anyone ID these nozzles? (Read 4072 times)
November 14, 2008, 11:32:33 am
November 14, 2008, 11:32:33 am »
I think this is "Smog"'s site? I don't know though.
I have these nozzles in my injectors and i don't know what size they are. now that i know a little more im curious to know.
http://www.veg-injection-service.com/store/index.php?main_page=product_info&cPath=6_8&products_id=29
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
November 20, 2008, 09:38:38 pm
November 20, 2008, 09:38:38 pm »
bump
anyone bought these nozzles before?
THROWN ROD
November 21, 2008, 08:55:47 am
burnt_servo
November 21, 2008, 08:55:47 am »
i've got a set of these in my car right now .
they have a flat spot on the needle if the injector that many people claim is desgined for self cleaning and thusly ideal for veg oil .
the flat spot causes a different spray pattern , and i found that at stock vw pop pressures , about 1/3 of the spray was droplets rather than mist .
until i got around 2500 psi then things started to clean up .
before my next trip to edmonton i've got a set of gtd nozzles i think i'm going to try .
1990 jetta , tweaked pump , tweaked turbo , ported head 2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
November 21, 2008, 10:33:47 am
November 21, 2008, 10:33:47 am »
FWIW Giles says he wouldn't use Merc nozzles himself, and having seen the spray pattern I've put the set I bought on the shelf unused as well. Like burnt_servo I found that the stock breaking pressure wasn't enough to generate the mist that the VW swirl chamber is expecting.
It's my understanding that the topology of a Merc head is quite different from the heads we use, and it would make sense that the nozzle design reflects that. Mind you, I don't use veggie....
My guess is that Burnt_servo is going to like the GTD nozzles just fine, at stock breaking pressures.
November 21, 2008, 11:10:38 am
November 21, 2008, 11:10:38 am »
I just went from the Merc tips to the "GTD" tips as well.
I didn't notice a difference in power but I do get a smother idle.
November 21, 2008, 11:41:35 am
burnt_servo
November 21, 2008, 11:41:35 am »
there is a "white paper " from vw on the beginings of the vw diesel around here somewhere .
after reading that i found out that vw uses a "swirl chamber " not the standard precup chamber alot of other engines use .
the swirl chamber allows the diesel to rev like a gas engine .
that also means the injectors need to produce a even . circular spray pattern to have a even swirl and even burn .
the merc tip only produce 2/3's of a circular spray , and 1/3 kind of sprays back in toward the centre of the circle with much much larger droplets .
this wouldn't be so bad if a guy could index the injector to the combustion chamber so a even amount of fuel is sprayed to both of the swirl impresions on the piston .
but the needle in the tip is able to turn in the injector , so this is impossible.
General Information
Troubleshooting
