Author Topic: WTB: Diesel Jetta Instrument Cluster 1986-1992 model years  (Read 4886 times)
November 13, 2008, 06:35:24 pm
wildenbeast
  • 50
    • The WILDENBEAST
« on: November 13, 2008, 06:35:24 pm »
Wanted To Buy:
A diesel instrument cluster from a diesel VW Jetta ranging from 1986-1992 model years.
Bill
303-775-5524
1990 Syncro Adventurewagen
1.9 Turbo Diesel (AAZ)
http://billwildenberg.shutterfly.com/vwvanagon
Reply #1November 15, 2008, 02:15:59 am
  • 2932
« Reply #1 on: November 15, 2008, 02:15:59 am »
I know an '86 is different than a '92.
 Do you want CE1 (2 plugs) ?
 or the later CE2 (1 plug)?
Reply #2November 15, 2008, 08:11:08 am
« Reply #2 on: November 15, 2008, 08:11:08 am »
Do you care if it has a tach or not? MPH or KPH?
Reply #3November 15, 2008, 05:23:42 pm
foxracer1
  • 991
« Reply #3 on: November 15, 2008, 05:23:42 pm »
Got one for an early MKII with a tach
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4November 17, 2008, 11:07:45 am
wildenbeast
  • 50
    • The WILDENBEAST
« Reply #4 on: November 17, 2008, 11:07:45 am »
I really will only use the tachometer out of it to place into my Vanagon's instrument cluster where the clock is currently located.  Please call me or pm me with how much you are willing to sell yours for.  I am ready to buy one ASAP.
Bill
303.775.5524
Reply #5November 17, 2008, 12:09:47 pm
Quantum TD
  • 1195
« Reply #5 on: November 17, 2008, 12:09:47 pm »
Quote from: "wildenbeast"
Bill
303.775.5524
I don't think that will work. The Vanagon housing for the tach is completely different AFAIK.
Reply #6November 17, 2008, 01:37:29 pm
« Reply #6 on: November 17, 2008, 01:37:29 pm »
Quote from: "Quantum TD"
Bill
303.775.5524
That's my understanding as well... iirc they are a completely different physical diameter, and the circuit boards are very different as well.
Might be worth a ping over in the Diesel Vanagon section of www.vwdieselparts.net to see what their experience has been ?
Reply #7November 17, 2008, 09:31:31 pm
foxracer1
  • 991
« Reply #7 on: November 17, 2008, 09:31:31 pm »
Not sure if it works but pmed ya
91 S10 305 TPI T56
Reply #8November 18, 2008, 10:38:13 am
wildenbeast
  • 50
    • The WILDENBEAST
« Reply #8 on: November 18, 2008, 10:38:13 am »
Ok.  I checked this out further with the mechanic that is helping me.  I don't know if it will work yet or not for sure but I'll let you know once installed since I already bought a tach from someone off the forum here.
Bill- The MKII tach housing is different, but I don't use the housing- I actually remove the tach itself, screw it onto the vanagon housing, and then use a vanagon instrument cluster with a tach and install it.  I have done this a few times with the gas engine tachs- I had one in my van as well.  I am pretty sure that I can make the diesel tach work as well,  the only thing that appears to be different is the signal coming in is from a different source (the alternator). instead of the ignition coil.  Can you send me a pic of the tach you bought, front and back?  It is possible that it won't fit, but even if the wiring connections are different, I think Ican change those around to make it work.
Lucas
