Author Topic: duno if anyone noticed  (Read 4521 times)
Reply #15November 11, 2008, 06:45:07 pm
oldskool rich
  • 446
« Reply #15 on: November 11, 2008, 06:45:07 pm »
sorry i thort clutched was one way, didnt know there was 2 different ones
i dont get why people are scared of the serpantine system, get a TDI alternator which is more reliabale and usualy more amps, if your worried about the pully then eather do what i did and use a tdi crank, of just drill a hole in the pully through to the crank and put a pin in it
Ive only had bad experiances with V belts, they always come loose sum how :roll:
as for aaz pump, they are superior but duno if its worth the hastle, its the only pump bracket i cud find in my bit box
f6squared I.D.S.T
Reply #16November 12, 2008, 05:31:14 am
saurkraut
  • 904
« Reply #16 on: November 12, 2008, 05:31:14 am »
Quote from: "oldskool rich"
How so?  This is news to me.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #17November 12, 2008, 02:17:51 pm
gigaz2
  • 626
« Reply #17 on: November 12, 2008, 02:17:51 pm »
yup, aaz pumps aren't superior in any way to a TD.
If the goal is to build a generator, one doesn't need to worry about alternators, in fact it doesn't even need one as you will already have a huge one connected to the crank anyway
EDIT: now that I think of it, for a generator you only need a NA pump, as the LDA will never be used, generators work in stationary mode, in a very narrow sustained rpm range.
usually an electronic controller is used to handle the throttle lever
